#21 | |
![]() Opening up an engine is usually an exercise in "check everything you can" vs "what else can go wrong?" or "gee, I gotta spend more money than I expected". Everything that can be checked will be. Everything will be cleaned to the best of my ability. Valve seats will be eyeballed too. I used to have an old-fashioned hand-crank valve lapping tool, I wonder what happened to it? Naturally, you can find them on ebay...
'31 Ford Deluxe Coupe "The Green Hornet" |
#22 |
Far be from me to question guys like Paul Shinn but I don't like the idea of putting something into the cylinder and making the piston push it against the head...I'm thinking bad stuff like hydro-lock and bent rods.
I have done two heads used the tools that screw into the plug holes and worked it loose. That video is very nice...a little too clean for me to believe. The head popped doff the hood could stay on no head studs twisted out with the nuts...man that was easy. My jobs took 6 hours and two days to remove the heads! |
#23 |
Sometimes they can be a bear to get off! Good luck https://youtu.be/MtgvnT6ab0U?si=q7mBc5n1MpTzgLMV
#24 | |
#25 |
I would pull the long water outlet studs to eliminate their effect on removing the head.
#26 |
Steve, Proud owner of 28 Fordor, been in family since 63 30 Tudor 31 S/W Town Sedan Skyline Chapter MAFCA, MARC |
#27 |
I use a jam nut on top of the regular nut, or if necessary two jam nuts, and remove as many of the studs as will come out. I use an eye threaded into a couple of spark plug sockets to pull upwards. A few smacks with a dead blow hammer on the side of the head, while pulling upwards, usually pops it loose. I do pull the manifolds off to get them out of the way. Plastic shims like you use to install doors can help and won’t damage machined surfaces, but be careful you don’t drive them against the valves.
Copper clad head gaskets are a lot easier to remove than graphite, but I think the graphite gaskets seal better.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan (under reconstruction) 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
#28 |
I use this type of stud remover, it is concentric and that seems better than other types.
https://shop.advanceautoparts.com/p/...3&gclsrc=3p.ds |
#29 |
#30 | |
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan (under reconstruction) 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! Last edited by JayJay; 03-12-2026 at 10:24 AM. |
#31 |
Ok, I received my package from Snyder's...and problem solved.
Rule #1: do the quick and easy first: now having the wrench to work around the Distributor, I re-torqued the head (in the proper sequence). Not a single nut was at 55in/lb. Some got a few degrees of rotation, some got more. Topped up the radiator, checked the oil and cranked her up, no steam. Let her get to temp (I have one of those cheap IR thermometers with the laser), no steam. Took her around the block, no steam. Stopped, eyeballed everything, rechecked all the fluids and put 10mi on her just looping around the neighborhood. Got her back in the driveway and temps were 200F at the rear of the head, 180F at the front. 145F in the upper hose and 130F at the radiator cap. And...my moto-meter isn't working... ![]() Looks like that took care of the problem! At least I now have a head gasket in reserve (and studs, nuts, etc.).
#32 |
FWIW, I find that my MotoMeter doesn't show any red until the water is about 180 or above (I have a temperature gauge).
#33 | |
![]() Living here in the South, I may add a temp gauge for summer driving. I just would like to keep the dash uncluttered as much as possible.
#34 |
I would retest the torque on the head bolts after the engines completely cold.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
#35 | |
oops, I was going to post a picture but looks like Flickr is down. Edit: Flickr back up.
#36 |
The modern motometers measure the steam temperature. If you see red it is way too hot. The antique ones were calibrated differently and were a better indicator of the actual coolant temperature.
