Hi guys.. will a crab distributor work on a 8ba engine?
It will but not without a lot of work and some changes.
I'm thinking the timing cover and the gears from my c59a would need to swapped over
Different cam... means teardown.
Not sure I understand - what is to be gained by making this change?
#7 | |
Thanks very much Pete.
That engine looks like a earlier motor withe the water outlets in the center of the heads.
I can get a 8ba short block without the distributor.
But I have a c59a engine complete. I also think the crab with its HT cabling looks far more athletic in my opinion.. just saying. |
Does the c59A run? Does it need rebuilt? Why don't you want to use it?
Yes the c59a runs fine despite a crack between a intake valve seat and the bore in cylinder 7.
#13 |
It's a later block with early style heads like this one.
#14 |
#15 |
Thanks Pete. Your enlargements always look so good.
