Old 01-11-2026, 10:57 AM   #5
dmsfrr
dmsfrr's Avatar
Default Re: Wiring a new voltage regulator-54 Mercury
I corrected this sentence in my previous reply.
Originally Posted by dmsfrr View Post
... The wire from the 'battery' terminal on the voltage regulator would connect to the 'battery' terminal of the starter solenoid.
The third and fourth images are a portion of a 6v Positive ground wiring diagram for a '55 T-bird. As pictured I believe the battery and starter are actually on opposite sides of the car. But other than that should be very similar to what you have regarding the basic wiring.
Hopefully they're not too small.
