Old 12-20-2025, 02:42 PM   #1
benbuilder
Default What model is my 30/31 frame?
I started working on my tutor project again. Kids are gone and now have some time.
Its a 1930/31 project car and I assumed that the frame and Body were from a tudor. The number on this engine was A4652868-May of 1931. Frame number is not recognizable. So no idea if they matched. I will call this OLD FRAME.
I noticed I needed a better frame so I bought a frame and engine. Frame number is A3088879-March 1930. I will call this FINAL FRAME.
I’ve started to test fit the wood blocks temporarily to the tudor body and OLD FRAME, and I’ve noticed the tudor body holes do not lineup with the holes in the OLD FRAME.
So I started to wonder what was going on. While comparing the two frames, I noticed that they are different. They are both definitely Model A frames. The difference is in the location of the bracket that mounts the body in the front A pillar. If I check those measurements, they are different between the two frames.
If you look at my pictures you can see that the FINAL FRAME(first pict) has a dimension from the center of the front axle to the a pillar mount bracket of 40 1/2". The OLD FRAME (second pict) has a dimension of 43 1/8" from the center of the front axle to the a pillar mount bracket.
There is a 3" difference- truck vs car?
The question I have is, what vehicle is the FINAL FRAME from?
I have been searching the internet for hours and all i come up with is that the frames are the same except for slight differences in holes and brackets.
Thanks
benbuilder is offline   Reply With Quote
Old 12-20-2025, 06:57 PM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: What model is my 30/31 frame?
Ford changed the placement of that bracket in 31. I’m not sure of month but someone here will likely get it to the month! It was to accommodate the slant body cars. Many non slants were placed on those frames and only one body bolt when thru the wooden block.
I’ve seen a few originals that way….but not many
Old 12-21-2025, 03:03 PM   #3
Gary WA
Gary WA's Avatar
Its a 1930/31 project car and I assumed that the frame and Body were from a tudor. The number on this engine was A4652468-May of 1931. Frame number is not recognizable. So no idea if they matched. I will call this OLD FRAME.
I noticed I needed a better frame so I bought a frame and engine. Frame number is A3088479-March 1930. I will call this FINAL FRAME.
Thanks
Here's all you need to know about frames.file:///C:/Users/Gary/Downloads/Evolution_of_the_frame_assembly2.pdf
www.whidbeymodelaclub.com
Old 12-21-2025, 09:05 PM   #4
ModelA29
ModelA29's Avatar
Originally Posted by Gary WA View Post
Here's all you need to know about frames.file:///C:/Users/Gary/Downloads/284242-the-evolution-of-the-model-a-frame-by-pluck
If you don't have access to Gary's computer the PDF is online. You'll need to do a search for the-evolution-of-the-model-a-frame-by-pluck. It will take you to another Model A forum where all Pluck's research has been posted since the demise of his website.
ModelA29 is offline   Reply With Quote
Old 12-22-2025, 02:47 AM   #5
Randy in ca
Randy in ca's Avatar
In September 1930 the body bracket on the frame was moved 2-3/8" to the rear for some models (Standard Fordor, Town Sedan and Victoria Coupe).
Randy in ca is offline   Reply With Quote
Old 12-22-2025, 04:28 AM   #6
Bruce of MN
Bruce of MN's Avatar
Using ModelA29's tip, I found https://pdf4pro.com/view/the-evoluti...oogle_vignette
This also turned up for reference: https://www.thebrassworks.net/blogs/...-frame-changes
Old 12-22-2025, 05:22 AM   #7
benbuilder
I was able to find the document on the frame changes last night. I see the note about the 2 3/8" change. I guess i will be moving this bracket. thanks for the help guys
From the document:
FRAME ASSEMBLY A-5005-On September 18, 1930, Release Number17050 Supplement #18 saw the BodyBracket on Frame – Front move to the rear2-3/8 inches
Old 12-22-2025, 12:04 PM   #8
rotorwrench
rotorwrench's Avatar
The change was made to accommodate the new cowls of the slant winshield cars that started first with the Victoria and then Fordor models came later. The 68C Cabriolet had a wood body sub-frame so it likely used the older type frame. The Tudor sedan was unchanged. For the most part, the model A frames are close enough that they can be altered to fit any year or model. Holes can be welded up & redrilled as needed. The only caveat is that the frame is the last resort for title and registration purposes due to engine changes and the like. Changing it could be problematic. Rusty frames can obscure the original numbers of a frame but some forensic type procedures can bring them back up for verification.
