Old 10-18-2025, 05:21 PM   #1
51shoeboxer
Default 1951 Steering lower sector shaft seal
It looks like the lower sector shaft has a seal that is pressed in. My question is how do I remove and replace it. Thanks
Also, on the ford barn is there a way to conduct a two or three word search, such as for sector shaft seal. If I put those three words in, the site seems to search for each individual word.
51shoeboxer is offline   Reply With Quote
Old 10-18-2025, 05:45 PM   #2
flatford8
flatford8's Avatar
Default Re: 1951 Steering lower sector shaft seal
I use google. I would search….sector shaft seal Ford Barn….thats how I search for this site……..Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 10-18-2025, 06:11 PM   #3
tubman
tubman's Avatar
Isn't there a qualifying phrase that you can use to limit the search to the Barn? Something like "Forum=The Ford Barn"? I seem to remember that it's a lot better than the native search.
Old 10-18-2025, 07:00 PM   #4
cas3
I'm with Mark, use google
Old 10-19-2025, 10:51 AM   #5
Kens 36
Kens 36's Avatar
Just put your search term in quotes: "sector shaft seal"
Ken
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 10-21-2025, 07:07 AM   #6
Terry,OH
Terry,OH's Avatar
After removing the pitman arm (suggest a mark on the pitman and the end of the sector for reassembly) clean the face of the old seal and look for stamped markings as to Mfg. and part number. Then drill about three small holes in the face of the seal and insert small, long sheet metal screws part way into the holes. Pull on the heads of the screws to remove the seal.
Old 10-21-2025, 04:22 PM   #7
Kube
Super Moderator
Kube's Avatar
Ha! Terry beat me to this response. I have been using this method for decades.
The only thing I do slightly different is I use self-tapping screws.
Old 10-24-2025, 03:00 PM   #8
51shoeboxer
Thanks for the suggestions.
Old 10-24-2025, 06:43 PM   #9
rotorwrench
rotorwrench's Avatar
I must have a half dozen different slide hammers for seals. I changed a bunch of small tail rotor gearbox & turbine gearbox seals as well as sector shafts on old cars. If the lube leaks out, the the load bearing surfaces wear out too. It's best to nip it in the bud on this stuff. Some are more difficult than others so I have a lot of special tooling for the job.
