Old 08-07-2025, 06:12 PM   #1
corvette8n
corvette8n's Avatar
Default New to me video French block vs 8BA,59AB
https://youtu.be/WfIwQpxbeAE?si=aaEhgMxaVlf-5N6u
Difference between French, 8BA, and 59a, I learned a lot.
Old 08-09-2025, 06:15 PM   #2
Shoebox
Shoebox's Avatar
Default Re: New to me video French block vs 8BA,59AB
Interesting, informative video. I was surprised the French blocks use SAE hardware.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 08-09-2025, 08:07 PM   #3
Tim Ayers
Thank you for sharing. Makes me want to hunt down on these French blocks.
Tim Ayers is online now   Reply With Quote
Old 08-09-2025, 09:18 PM   #4
big deuce
big deuce's Avatar
Casting date on mine is 1978...they didn't mention in the video that there are clearances in the lower end of the block for more stroke than the 4" crank. I didn't realize the exhaust studs were wet... I have read to leave the studs in, don't even think about trying to remove them if you get one with exhaust studs. I just got 10mm nuts for the metric end of the stud. The timing cover has a thrust bushing with a locknut to prevent cam walk.
big deuce is offline   Reply With Quote
Old 08-11-2025, 01:40 PM   #5
Rockymountainsparky
Rockymountainsparky's Avatar
That was a great video. Very informative. Thanks for posting.
Rockymountainsparky is offline   Reply With Quote
Old 08-11-2025, 02:57 PM   #6
petehoovie
petehoovie's Avatar
More excellent pictures here > https://www.35pickup.com/FrenchFlathead.html
Old 08-11-2025, 06:50 PM   #7
Wangstang
Originally Posted by corvette8n View Post
YoutubeVideo (I've been around the Garage Journal for years, along with several other car forums, but I've finally opened an account profile here so I'm new to this forum and the system won't let me quote the link)
Thanks for sharing this. Working on a 46 ford with the potential to need a new engine block and I think the French block may work out for me.
I've been doing some reading and I get the impression that the 48-53'ish flathead blocks that were built for use in the F2 and larger series trucks used a block similar to the French design. Is that good information or bad information?
Wangstang is offline   Reply With Quote
Old 08-11-2025, 08:13 PM   #8
alchemy
alchemy's Avatar
Bad information.
alchemy is offline   Reply With Quote
Old 08-11-2025, 09:29 PM   #9
Tim Ayers
Unless it has one of those big flatheads (339 c.i. or something like that), they all got the same blocks. As Alchemy stated, you got some incorrect info.
