Old 06-05-2025, 12:52 PM   #1
Brian SATX
Brian SATX's Avatar
Default Any idea what this tool is?
Wondering what this is. I found it in an area where my wife's cousin used to do a lot of work on cars. It is about 6 inches long. The large end is either 1' or 7?8". One end lookshuttool.jpg like a bottle opener.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 06-05-2025, 02:27 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Any idea what this tool is?
It would be considered a multi-tool. It probably came as a tool kit item for some mechanical aperatus. The end has a slot spanner to fit nuts with slots instead of hex flats.
Old 06-05-2025, 04:12 PM   #3
Gary WA
Gary WA's Avatar
Torch wrench?
www.whidbeymodelaclub.com
Old 06-05-2025, 05:40 PM   #4
Keith True
Keith True's Avatar
Could be any one of a thousand applications.The type of tool that came with the unit it is used on.I have something like that for the old Homart piston water pump.While yours is still an 8 point,for square plugs or nuts,it is open.Mine is closed for the priming plug.
Old 06-06-2025, 08:36 AM   #5
stevemclark
stevemclark's Avatar
Looks a little like a water pump tool, but not it,I don't think it's a ford tool either. https://www.mikes-afordable.com/product/T8501W.html
It's not the destination ,it's the journey .
stevemclark is offline   Reply With Quote
Old 06-06-2025, 09:30 AM   #6
WTSHNN
WTSHNN's Avatar
A google image search turned up no exact matches but hundreds of similar style multi-tools. Most of those results describe the tool as a bicycle wrench.
-Tim
No one wants advice - only corroboration.
-John Steinbeck
WTSHNN is offline   Reply With Quote
