The Ford Barn
-   -   Any idea what this tool is? (https://www.fordbarn.com/forum/showthread.php?t=349684)
Brian SATX 06-05-2025 12:52 PM
1 Attachment(s)
Wondering what this is. I found it in an area where my wife's cousin used to do a lot of work on cars. It is about 6 inches long. The large end is either 1' or 7?8". One end looksAttachment 567709 like a bottle opener.
rotorwrench 06-05-2025 02:27 PM
Re: Any idea what this tool is?
It would be considered a multi-tool. It probably came as a tool kit item for some mechanical aperatus. The end has a slot spanner to fit nuts with slots instead of hex flats.
Gary WA 06-05-2025 04:12 PM
Torch wrench?
Keith True 06-05-2025 05:40 PM
Could be any one of a thousand applications.The type of tool that came with the unit it is used on.I have something like that for the old Homart piston water pump.While yours is still an 8 point,for square plugs or nuts,it is open.Mine is closed for the priming plug.
stevemclark 06-06-2025 08:36 AM
Looks a little like a water pump tool, but not it,I don't think it's a ford tool either. https://www.mikes-afordable.com/product/T8501W.html
WTSHNN 06-06-2025 09:30 AM
A google image search turned up no exact matches but hundreds of similar style multi-tools. Most of those results describe the tool as a bicycle wrench.
-Tim
