Old 05-18-2025, 10:56 AM   #1
GaryU.
GaryU.'s Avatar
Default Holland, Michigan flathead. C- List
Just saw this for $50.00, but what's with the large generator and extra mystery attachment?? https://detroit.craigslist.org/okl/p...850681233.html
GaryU. is offline   Reply With Quote
Old 05-18-2025, 11:14 AM   #2
cas3
Default Re: Holland, Michigan flathead. C- List
Interesting. Maybe hydraulic pump for a plow or power steering on a truck. Funny place for the oil filter too. If it was close to home, it would already be in my garage and I could tell you more about it!
cas3 is online now   Reply With Quote
Old 05-18-2025, 11:27 AM   #3
big deuce
big deuce's Avatar
Looks like a 40-41 with the crank mount fan
big deuce is offline   Reply With Quote
Old 05-18-2025, 02:06 PM   #4
petehoovie
petehoovie's Avatar
Old 05-18-2025, 02:08 PM   #5
jimTN
May be a cab over or bus engine
Old 05-18-2025, 02:22 PM   #6
1952henry
1952henry's Avatar
Perhaps a governor?
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 05-18-2025, 02:50 PM   #7
KiWinUS
KiWinUS's Avatar
Yep Henry has it. Govenor has friction pulley that drives off outside of fan belt. Generator is 3 brush with cutout broken off leaving just base.
Old 05-18-2025, 03:31 PM   #8
leon bee
Were governors just so guys would take it easy on the truck?
leon bee is offline   Reply With Quote
Old 05-18-2025, 03:31 PM   #9
cas3
yup, I see the springs for the governor now. Probably off a stationary power unit. Wonder whats on the back
Old 05-18-2025, 03:39 PM   #10
ford38v8
ford38v8's Avatar
Am I correct in assuming that a stationary engine would at the very least require the ring ridge removed before installing in a car?
Alan
Old 05-18-2025, 05:25 PM   #11
KiWinUS
KiWinUS's Avatar
What’s a ring ridge and how does it affect what it is installed in?
Old 05-18-2025, 11:55 PM   #12
ford38v8
ford38v8's Avatar
A ring ridge is the topmost area of a cylinder bore that remains free from wear caused by the top piston ring, which becomes more pronounced as the engine wears. A seat-of-the-pants judgement of engine wear is often done by feel with one’s fingernail at the top of a cylinder. Perhaps you know of it by another name.
Alan
Old 05-19-2025, 06:00 PM   #13
Manuel
Bus engines had those big fat generators.
Manuel is offline   Reply With Quote
Old 05-19-2025, 06:38 PM   #14
Tim Ayers
Worth $50 just for the pulley off that generator. Anything else is gravy on top.
Old 05-20-2025, 12:34 AM   #15
big deuce
big deuce's Avatar
That front gen pulley probably has the .590 diameter shaft, since its a older 3 brush...
Old 05-20-2025, 07:10 AM   #16
Tim Ayers
Ah, yes. You are likely correct.
