Old 02-27-2025, 11:28 AM   #21
Bored&Stroked
Bored&Stroked's Avatar
Default Re: 40 flathead EFI
If I was heading down this path, I would surely use the Holley system as their EFI software is REALLY good (if it is the same software used on their other systems). Also, there are a lot of tuner/dyno folks that know how to USE the software - which is even more important.
Old 03-28-2025, 02:59 PM   #22
Thomas Sargent
Thomas Sargent's Avatar
EFI project completed. Engine started instantly on the first try. This is the autotrend unit from CA. Installed Manifold pressure sensor, ambient air temp sensor, coolant sensor, idle air control motor, , throttle position sensor was on throttle body, and one wire went to coil. installed O2 sensor in pas ex pipe, and a Holley HP processor under the seat, pass side. Put in the tank fuel pump and pressure reg in engine compartment. Lots more details, DSC02703.jpg
Thomas Sargent is offline   Reply With Quote
Old 03-28-2025, 04:03 PM   #23
mfirth
Wow, that is nice. Nice job !
mfirth is offline   Reply With Quote
Old 03-28-2025, 04:32 PM   #24
Tim Ayers
Awesome. Glad it works so well.
Old 03-28-2025, 06:03 PM   #25
petehoovie
petehoovie's Avatar
Old 03-28-2025, 06:21 PM   #26
mrtexas
mrtexas's Avatar
EFI project completed. Engine started instantly on the first try. This is the autotrend unit from CA. Installed Manifold pressure sensor, ambient air temp sensor, coolant sensor, idle air control motor, , throttle position sensor was on throttle body, and one wire went to coil. installed O2 sensor in pas ex pipe, and a Holley HP processor under the seat, pass side. Put in the tank fuel pump and pressure reg in engine compartment. Lots more details, Attachment 563649
Attachment 563650
Attachment 563651
Attachment 563652
Cost?
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 03-30-2025, 10:18 AM   #27
Thomas Sargent
5 K for the throttle body package. 800 for fuel pump kit from Tanks, 200 for the intake manifold, 200 for the air cleaner, 50 for the filter from K &N,(not shown in pix),about 70 hours labor
Old 03-30-2025, 10:20 AM   #28
Thomas Sargent
Three dollars for the nerve pills and Tums
Old 03-30-2025, 11:12 AM   #29
tubman
tubman's Avatar
"Starts immediately" is encouraging. Have you had it out on the road yet?
That's what I'd like to hear about. Keep up the good work!
Old 03-30-2025, 01:08 PM   #30
KiWinUS
KiWinUS's Avatar
I will try to load a pic and video of an engine I built for a great couple of guys with Fuel injection. Unfortunately can’t load video.
KiWinUS is online now   Reply With Quote
Old 03-30-2025, 01:12 PM   #31
Bored&Stroked
Once the partial load and road-test tuning is done, my bet is that it will run extremely well, get great gas mileage and be a total pleasure to drive. You did some really nice work on the install!
Old 03-30-2025, 01:55 PM   #32
tubman
tubman's Avatar
I like stuff like this. It's kinda like the time I tried to put a Quadrajet on a flathead using a Sharp 4 BBL manifold and a couple of adapters. It didn't work well the first time, but I may try it again, this time with a new carb from a 3.8L Chevy instead of a junk 455 Olds carb I tried to rebuild myself.
Old 03-30-2025, 02:27 PM   #33
jimTN
Dynometer reading, before and after would be interesting.
jimTN is online now   Reply With Quote
Old 03-30-2025, 05:18 PM   #34
Bored&Stroked
Yeah, I'd love to see some chassis dyno sheets on this new combination!
Old 04-04-2025, 10:44 AM   #35
Thomas Sargent
Road trip today. Computer learning quickly. Smooth thru the gears. can start out at idle now with no pedal nicely. Was low on gas so returned to garage. Also need to minor adjust the clutch. Had it up to 35mph. Looks very promising. All vitals good on engine Snow storm coming next week so stay tuned.
Old 04-04-2025, 01:24 PM   #36
Seth Swoboda
Seth Swoboda's Avatar
Post a video of this starting up and running please.
Old 04-24-2025, 02:58 PM   #37
Thomas Sargent
Logged 30 miles today with the throttle body EFI. The computer is learning fast. This has met all my expectations so far. I filled up the gas tank in order to get a mpg. The display I have indicates air fuel ratio bouncing around 13 so that seems rich. I am using just the mechanical advance on the Stromberg distributor. Without a crank trigger there is no way for the timing to be managed by the computer. Will continue to drive for developments but so far so good.
Old 04-25-2025, 07:55 AM   #38
Thomas Sargent
can't figure out how to post a video. site says a token is missing?
Old 04-25-2025, 08:27 AM   #39
glennpm
glennpm's Avatar
You can't post then directly but you can post it on YouTube and then provide the link here. Like to see it.
https://socialbee.com/blog/how-to-post-on-youtube/
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 04-26-2025, 06:24 AM   #40
Thomas Sargent
here is my first try with youtube
https://www.youtube.com/watch?v=p7OsSdsdZFc
If this works out I will post more video
