Old 12-11-2024, 11:22 AM   #1
Thomas Sargent
Thomas Sargent's Avatar
Default 40 flathead EFI
I have been bumping around trying to fugure out how to install a Holley sniper 2300 on my 1940 ford flathead. Looks like the sniper will manage the correct amount of fuel for this displacement. Problem seems to be finding a manifold and or adapter that will mate the Holley 2300 flange to the mainfold somewhere in the middle. Has anyone solved this fit problem in a sensible way? Has anyone done this already? seems like an interesting idea Thanks in advance Tom Sargent
Thomas Sargent is offline   Reply With Quote
Old 12-11-2024, 11:49 AM   #2
tubman
tubman's Avatar
Default Re: 40 flathead EFI
There were a couple of users on this forum who were into fuel injection, "ken henry" and "kilohertz". Do a "search" on their names and you should find a lot of stuff. As I remember, they had some good results.
As for an intake manifold for the application you're talking about, I'd start with a late model Mercury 4 bolt manifold. I'm sure there are adapters available and they can be bored out quite a bit.
Old 12-11-2024, 06:24 PM   #3
cadillac512
cadillac512's Avatar
Pretty sure Holley offers a system to fit the 2G Rochester base, and that's same as the flathead Merc intake uses. No adapter needed for that.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 12-11-2024, 06:42 PM   #4
ActionYobbo
ActionYobbo's Avatar
This manifold and a piece of 1/2 inch aluminum plate to make the adapter. Take the high rise portion off and mount your adapter there. Won’t be hard to make an adapter out of a chunk of flat
https://www.lunatipower.com/4-barrel...ezSTI2dI&gQT=1
I am building a 1939 1 ton express
ActionYobbo is offline   Reply With Quote
Old 12-11-2024, 07:38 PM   #5
tubman
tubman's Avatar
I'd be willing to bet that any system they make would match a large base 2G; the Merc's are the same as the small base 2G. I did find a couple of sources for 2300 to small base 2G adapters. (Large base to small base 2G adapters are problematic as the bolt patterns are quite close.)
Old 12-13-2024, 07:28 AM   #6
Dak Rat
The Holley EFI kit 550-866 is designed to fit the small base 2GC manifold. Will bolt right on the merc intake.
Dak Rat is offline   Reply With Quote
Old 12-13-2024, 09:10 AM   #7
cadillac512
Exactly.
Old 12-13-2024, 12:04 PM   #8
tubman
tubman's Avatar
I stand corrected. Small base 2G stuff is usually hard to find.
Old 02-26-2025, 09:41 AM   #9
Thomas Sargent
I have found a company in CA called autotrend that makes a throttle body that looks like a stromberg. http://www.autotrendefi.com/products.html In the midst of instillation. Obtained a used aluminum manifold with single carb tower from Millworks . Have installed an intank fuel pump in my poly Tanks fuel tank. That went well. Stay tuned for a full report later after we get it running
Old 02-26-2025, 09:49 AM   #10
Seth Swoboda
Seth Swoboda's Avatar
An EFI flathead, I'd like to see this when you are done. It might be kind of wild for the fordbarn but I'm really curious about your results.
Seth Swoboda is offline   Reply With Quote
Old 02-26-2025, 12:45 PM   #11
Tim Ayers
I was in North Carolina this past week and checked out Craigslist.
Someone is selling a a complete and new Flatattack TPI set-up for a reasonable price I thought.
Here is the link:
https://greenville.craigslist.org/pt...813253164.html
Old 02-26-2025, 12:58 PM   #12
Newc
Newc's Avatar
I have two 4bolt 8CM manifolds for Sale. One steel $75 and one Canadian aluminum $175 all + shp from Oregon. Newc
Old 02-26-2025, 01:19 PM   #13
tubman
tubman's Avatar
Here's an idea. Does anyone make an EFI to replace a small base 2G? Might as well pick up some performance while you're at it.
Old 02-26-2025, 01:34 PM   #14
Tim Ayers
Yes. That unit from Autotrend is a 2G replacement according to the info on their webpage
Old 02-26-2025, 01:57 PM   #15
petehoovie
petehoovie's Avatar
Old 02-26-2025, 02:07 PM   #16
petehoovie
petehoovie's Avatar
Originally Posted by Thomas Sargent View Post
I have found a company in CA called autotrend that makes a throttle body that looks like a stromberg.http://www.autotrendefi.com/products.html In the midst of instillation. Obtained a used aluminum manifold with single carb tower from Millworks . Have installed an intank fuel pump in my poly Tanks fuel tank. That went well. Stay tuned for a full report later after we get it running
Old 02-26-2025, 02:10 PM   #17
petehoovie
petehoovie's Avatar
Here is the link:
Ford Flathead Engine Fuel Injection - $1,700 (Seneca)
Old 02-26-2025, 02:15 PM   #18
Tim Ayers
Did the 2G's ever come in three bolt bases?
Old 02-26-2025, 02:21 PM   #19
tubman
tubman's Avatar
Not that I have ever heard. Even if they did, it wouldn't do a lot of good, because a Ford 3 bolt intake can't be bored out enough to match the 2G throttle bore size without sleeving and a lot of extra effort. That's why they made Mercury 4 bolt manifolds.
Old 02-26-2025, 02:33 PM   #20
Tim Ayers
Gotcha.
