Old 03-20-2025, 10:18 AM   #18
JayJay
Default Re: Clutch release arm crack
Originally Posted by TomInCologne View Post
...but the longer arm makes it easier to crack it... ;-)
The force applied at the shaft is determined by the resistance from the pressure plate springs. If the shaft did not turn then yes, the force applied would be higher with the longer arm (assuming this same push by the leg), but since the shaft does rotate, no the longer arm would not make the bracket more prone to breakage.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
