Clutch release arm crack 1 Attachment(s)
This happened to me a few years ago and i know of about 4 others, You can't release the clutch. I got it off and got a foreign replacement from Brattons it was slightly small. Trying to beat it on it ruined the fork. I got an original,pulled the rear, trans,and bell, drove the shaft out and removed the bad one, reassembled the fork and original arm with pins,put the trans and rear back and swore not to buy any more foreign crap
Re: Clutch release arm crack Quote:
I had the same problem, cracking the arm. Obviously my feet are too heavy. But don't blame this on 'foreign crap', this arm was a bad engineering from Henrys men... |
Re: Clutch release arm crack I agree with Tom on this. The original design has a smaller pin and when that was increased in diameter the arms started cracking. I carry a spare arm. I wonder if a heavy duty hose clamp or two would prevent the arm from cracking.
Re: Clutch release arm crack Besides being of questionable design, after almost 100 years of use, we are seeing more and more cases of this arm failing due to metal fatigue these days. I have replaced three in the last year alone! Old-timers in the hobby can attest that this wasn't a major problem 20-25 years ago and has increased in frequency since then. The new repo arm is much stronger, although the staking pin area will always be the Achilles heel. Too bad that you'll probably have to replace the new arm again in another hundred years. :)
M. |
Re: Clutch release arm crack If it was a design problem there would have been a service bulletin.
If it was a common problem when the cars were less than 10 years old Pep Boys and other aftermarket parts catalogs would have them advertised. Yes to have them start failing after 75 years is a design failure— they were made too good. |
Re: Clutch release arm crack Replace it with an original '28 version for more leverage................
Re: Clutch release arm crack There used to be a billet steel version of the clutch arm available, but I don't see it now. I think I may have one laying around somewhere...
Re: Clutch release arm crack I think some of the failures nowadays may be related to the modern pressure plates with springs that are too strong, out of spec.
Re: Clutch release arm crack This happened to me approx 30 years ago. The replacement had a bigger round part and worked well. It looked like a forging, not a casting. I do not remember where i got it.
Vic |
Re: Clutch release arm crack There are two versions of the A-7511 clutch release shaft arm being sold currently. One is a replica of the original, while the other uses significantly more material. Both claim to be US-made.
https://www.snydersantiqueauto.com/c...s/A-7511-B.jpg https://modelastore.com/image/cache/...21-600x800.jpg Tom Endy wrote an article in which he speculates that some instances of broken clutch arms may be due to an erroneous service bulletin that recommended modifying A-7511-B arms to accommodate a larger pin, while the A-7515-B fork would need to be replaced as it could not be safely adapted. He hypothesized that this advice was reversed from what the engineers intended – that the fork be modified and the arm replaced. |
Re: Clutch release arm crack The second one alexiskai shows is longer than the original to make it easier to disingage the clutch. I have been using those for years, no problen, no fit problem either.
Ford eliminated the woodrof key when they went to the larger pin on both the fork and arm (Service Bulletins page 351). |
Ed |
Ed |
...but the longer arm makes it easier to crack it... ;-) |
and then, when the clutch is totally released, your foot works against the stop. with a longer lever. Don't ask me how i know, explaining it will be embarrassing for me. Edit: only true if the 'stop' is within the clutch and not within the pedal mechanism... |
Re: Clutch release arm crack 1 Attachment(s)
https://www.fordbarn.com/forum/attac...0&d=1742490344 Although I did break my original one!! https://live.staticflickr.com/4540/3...7a6fe29778.jpg |
| All times are GMT -5. The time now is 01:03 AM. |
