Old 03-10-2025, 11:19 AM   #41
jiw1
Default Re: Wheel Cylinder issues
i am having this problem on my 46 merc new off shore right side rear wheel cyl. is leaking.it is leaking on the 11/8" side of the cyl.what do i look for and what can i do to fix it ? thank you,ij
jiw1 is offline   Reply With Quote
Old 03-10-2025, 02:36 PM   #42
Mart
Mart's Avatar
See if anything in this video helps.
https://youtu.be/4QhP2xwqxjA?si=UinEhUTL4yWxH1Rq
Have a look at your rear cylinders and see where the hole is drilled.
