Old 04-21-2023, 07:52 AM   #1
Ronnieroadster
Ronnieroadster's Avatar
Default Wheel Cylinder issues
Here's the short story.
Doing some long overdue maintenance on my high milage Deuce Roadster
which includes front brakes. One of the original {USA} front wheel cylinders was leaking so I decided to replace both with new wheel cylinders. The new cylinders are now import quality so of course one of them leaked really bad during the bleeding process. Discovered the problem was the cup in the cylinder.
At this point I'm not crazy about the poor quality of this import stuff!
What I would like to do is just freshen up my original wheel cylinders. To do the rebuild I need 1-3/8 and 1 inch wheel cylinder cups. Would anyone know where I can get the cups in these sizes?
Also wondering what other have done when they needed wheel cylinders.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
