Old 01-21-2025, 11:13 AM   #21
Seth Swoboda
Seth Swoboda's Avatar
Default Re: Any one have a tried and true method for this one
I think some carefully applied heat will help loosen the plug and it should turn out easy.
Old 01-21-2025, 12:00 PM   #22
OldGold360
Originally Posted by Kube View Post
Pipe wrench will grab it and USE heat!
This is the correct answer!
Vise-grips will also work in place of a pipe wrench. You don't need to get it cherry red. Just a little heat should be all you need but it will let you know just how much it needs.
OldGold360 is offline   Reply With Quote
Old 01-21-2025, 12:46 PM   #23
cas3
heat the plug and it will expand and get tighter. Let it cool and it will shrink. heat the area around the plug will expand, however its cast iron which does not always play well with heat
Old 01-23-2025, 10:49 PM   #24
BoxCar Tom
BoxCar Tom's Avatar
Sorry wrong thread
BoxCar Tom is offline   Reply With Quote
Old 02-02-2025, 10:31 PM   #25
Pamlico
Pamlico's Avatar
Why mess with it? If it doesn't leak, leave it alone.
Pamlico is offline   Reply With Quote
Old 02-03-2025, 12:31 AM   #26
Eagle43
If none of the above suggestions work, simply drill it out to a diameter just shy of the threads. Then use a sharp punch to force the thin remaining shell to the middle and break it free and take it out in pieces. I'm assuming you can access it with a drill.
Eagle43 is offline   Reply With Quote
