#1 |
Does anyone have a tried and true method for removing a female plug?? This one is tight BUT it also doesn't help that the allen hole is fubar'd and the standard 5/16 will not grab under a load. BEFORE I start either heating and welding and or grinding I figured I would ask
#2 |
You have quite a bit of the plug proud of the manifold. You should be able to grab it with vice grips or cut a slot across the diameter . A roofer's shingle removal tool at 90° would give you good leverage.
I'd heat the manifold up with a heat gun if required. I'd also suggest PB Blaster but not much help with the manifold mounted.
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat’s Notes Techno Source for the 1932 thru 1953 Flathead Ford |
#3 |
Robert,
I've used those "sockets" that are a male plug with a spiral toothed flute around the outside that you drive into the female section and the bit grips it from the inside. They obviously destroy the plug, but have worked every time. |
#4 |
Would a metric Allen wrench do the job? 5/16" is a shade smaller than 8MM.
#5 | |
You're on the same wave length as I was.....I tried an 8mm but it fit just like the 5/16 did. I have a 9mm coming as well as an 11/32 Allen socket to see IF maybe they will fit tight.....IF not just close enough I can hammer it in even tighter. That is my thought/plan/direction at this point.....THE other ISSUE I am facing IS these are famous for cracking IF its not done just right!!!! SO...there is that too!!!!! My "other" Idea was to "maybe" grind a flat spot on two sides to fit a wrench on it as well AS "IF" the 9mm or 11/32 allen fits it to act as a "helper". |
#6 |
#7 |
Super Moderator
Pipe wrench will grab it and USE heat!
#8 |
#9 |
#10 |
You could try hammering in a suitably sized torx bit.
Personally if a pipe wrench couldn't do it I would be tempted to weld something to it. A piece of scrap metal bar or a big nut. |
#11 | |
these approaches used with care should get it to release. I have successfully remove same or similar using one or all of these suggestions. no doubt key is 1) break corrosion hold 2) get lube down inside threads 3) do not overpower metal's strength limits... Good Luck! let us know how you do.
"My Model A... work never ends, only the day ends!" |
#12 |
Don’t laugh but try wax. I had some stuff rusted together and could not get it out with vice grips and pipe wrench. I heated it up some and melted wax in the joint. I left the vice grips still attached and sticking out horizontally. The next morning the vice grips we’re hanging straight down.
#13 |
I would drill a proper size hole in a piece of flat stock, slip it over the end and tack it in 4 spots with a welder. Remember, when metal is heated it expands but when it cools it shrinks to be slightly smaller than it started out. Cooling it faster causes it to shrink more.
In this case, coolant could be a shot of penetrating oil. once it moves, grind off the spot welds and go back the the allen wrench |
#14 |
Call your plumber.
#15 |
Many good suggestions. I have used a tool sold by Eastwood that utilizes an air driven impact (like used with chisel) and a lever where you can put some leverage on it. Surprisingly effective when nothing else works such as VISE grips.
TomC750 1949 8NV8 Ford tractor 1930 1 Ton White 1941 Mercury Sedan Coupe |
#16 |
We remove stuck plugs in engine parts every day at work. Use an oxy/acetylene torch to heat the plug only(not the manifold) to a dull red. Have an air blow gun ready,turn off the torch and immediately blow air into the center of the plug to quickly cool it. Keep blowing until it cools down enough to work with it, and spray some penetrant on the threads. If it smokes it's too hot. The rapid cooling shrinks the plug, breaks the bond and they usually come right out with very little pressure.
"It don't take but country smarts to solve the problem" (Smokey Yunick) '30 Model A Speedster '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302
#17 | |
#18 |
We took broken bolts out of engines at work by welding a nut to them. I probably did this at least twenty times over 30-years and I never screwed anything up. That one should be easy to weld a nut to it as longs it's a steel plug and not brass one.
Be careful you don't break the corner of that casting off. |
#19 |
I agree, welding a nut is very good, but in this case the outer diameter allows for greater strength than the inside of a nut. Drill a hole in flat stock that fits around the outside will give about an inch of strength and leverage, over a nut welded inside.
#20 |
Thank you for ALL your responses, I will get the area cleaned of all paint and start with that.....I think I will look at inducing heat along with, "hopefully" one of the "slightly" bigger allen sockets I have coming that will fit the hex tighter than what I already have. It will be a few days before I can get back to it as we here in North Florida are expecting sleet, snow and Ice in the next day and NO heat in my shop SO I will keep all here posted of my results when I can.
