Old 12-29-2024, 04:51 PM   #1
TJ
TJ's Avatar
Default strange bell housing
Attached is a photo of a strange bellhousing. An early V-8 transmission will bolt up to it , but I have no idea what motor it goes to, but I suspect it might be a tractor. Seeking a possible answer.
Old 12-29-2024, 05:38 PM   #2
cas3
Default Re: strange bell housing
Looks like its set up for steady rods, like to put an 8ba into an earlier chassis. got a Ford # or any other markings?
Old 12-29-2024, 06:13 PM   #3
TJ
TJ's Avatar
I'll double check it, but my first inspection did not reveal any numbers.
Old 12-29-2024, 06:28 PM   #4
pistonbroke
Just looking at it , one would say 331 Cadillac to a early ford. Tim
Old 12-29-2024, 06:53 PM   #5
tubman
tubman's Avatar
You may be right. Looking at it after your comments, it does appear a little "aftermarketish".
Old 12-30-2024, 06:08 PM   #6
Tim Ayers
I think you are right. Is there are part # cast into it? If so, post it.
Tim Ayers is online now   Reply With Quote
Old 12-30-2024, 08:11 PM   #7
TJ
TJ's Avatar
I will look at it again and double check.
Old 12-30-2024, 08:53 PM   #8
Krylon32
I've have a strange bell housing I acquired a couple years ago. Looks like a 49-50 Merc stamped intermediate bell housing (8BA front bolt pattern, early Ford trans rear bolt pattern) only it's a little over a half inch deeper? Nobody has been able to tell me what it fits.
Krylon32 is offline   Reply With Quote
Old 12-31-2024, 05:57 AM   #9
Mac VP
Mac VP's Avatar
Almost certainly that is the bell that Ford used on the 48-51 H series flathead 226 six cylinder engine.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 12-31-2024, 06:32 AM   #10
38 coupe
38 coupe's Avatar
I am hesitant to post since Mac is more knowledgeable than me (and everyone else) on old Ford transmission and transmission related items, but that is not a normal 48-51 flathead six bell housing. The H series truck bell housings look very similar to the V8 units, except the bolt hole spacing for the engine block is different. I'm guessing the unit in question is aftermarket or for a stationary power unit.
Old 12-31-2024, 01:53 PM   #11
TJ
TJ's Avatar
O.K. I went over this piece with a fine tooth comb and found no part number. I did find some red paint, which withstood my wire brushing. The starter end cover appears to be longer and possibly larger in diameter than a Ford cover.
Old 12-31-2024, 04:49 PM   #12
pistonbroke
I have never seen a early ford six bell so Mac is probably right. The reason I said 331 Cad to early ford is I just removed had rebuilt and installed one in my brotherinlaws 52 Cad and that bell looks like it would bolt right on the Cad block. Which like the pre 49 ford V8s has the main bellhousing as part of the block casting . Cadillac and Olds overhead valve engines were comon swaps for street roders back in the day so I thought adaptor rather then bell. Tim
Old 12-31-2024, 05:26 PM   #13
Bob C
This is a 1948 H series 6 cyl bell housing.
Old 12-31-2024, 07:24 PM   #14
TJ
TJ's Avatar
Bob, is that a cast iron bell or stamped steel? The one I have is cast iron.
Old 12-31-2024, 10:01 PM   #15
Bob C
Stamped steel.
Old 12-31-2024, 11:32 PM   #16
cas3
The ears for steady rods is the oddity.
Old 01-01-2025, 12:02 AM   #17
Lanny
Lanny's Avatar
Just a guess, could that bell be for the V-12 Flathead engine ?
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 01-01-2025, 01:56 AM   #18
petehoovie
petehoovie's Avatar
Old 01-01-2025, 01:56 AM   #19
petehoovie
petehoovie's Avatar
Old 01-01-2025, 10:45 AM   #20
flatford8
flatford8's Avatar
The location of the starter cup is different……..Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
flatford8 is online now   Reply With Quote
