Old 12-27-2024, 10:47 PM   #1
Pobrian
Pobrian's Avatar
Default Small gauges to not be obvious
I have a 35 Tudor 48 and would like to monitor both sides water temp and oil pressure any ideas the smaller the gauges the better as I don't want them to stick out like a sore thumb
Pobrian is offline   Reply With Quote
Old 12-27-2024, 11:49 PM   #2
aussie merc
aussie merc's Avatar
Default Re: Small gauges to not be obvious
a thought if going after market 1 gauge 2 senders and a change over switch
aussie merc is offline   Reply With Quote
Old 12-28-2024, 08:06 AM   #3
corvette8n
corvette8n's Avatar
A lot of people mount these in the glove box. My set has a mechanical oil pressure gauge. Face of each gauge is only 1-1/2 in dia.
Old 12-28-2024, 11:14 AM   #4
TJ
TJ's Avatar
I have mounted extra gauges in the passenger cowl panel. You can look over at them to see what is happening with the motor.
Old 12-28-2024, 11:56 AM   #5
19Fordy
19Fordy's Avatar
TJ, Can you please post a photo of those "cowl panel" gauges. What size are the gauges?
Thanks.
Old 12-28-2024, 02:37 PM   #6
TJ
TJ's Avatar
Jim, I'm a little lame when it comes to posting photos, but I used the Stewart-Warner Wings gauges in my '32 cabriolet which I no longer own. Those gauges are two and a quarter overall diameter. They looked right in the car with the stock '32 gauges. I also wired them to the light switch so you could see them at night. I looked at mini gauges but I thought they were too small to see from the driver's seat.
Old 12-28-2024, 05:05 PM   #7
69a
A good idea when using multiple gauges, is to "clock" them so the needle is vertical in the normal operating position. That way you can tell at a glance what needs more attention.
69a is offline   Reply With Quote
Old 12-28-2024, 05:11 PM   #8
ssffnomad
ssffnomad's Avatar
Stewart Warner Wing guages.
Wood Grain to match the Dash.
ssffnomad is offline   Reply With Quote
Old 12-28-2024, 06:38 PM   #9
koates
I have three mini gauges mounted in a panel under the center dash panel and find they are rather hard to read in a hurry. Have to take your eyes off the road for too long to decipher the readings correctly. I would go for the standard size 2 1/8" gauges if they can be fitted in. Regards, Kevin.
koates is offline   Reply With Quote
Old 12-29-2024, 07:44 AM   #10
glennpm
glennpm's Avatar
Attachment 557867
Very nice setup.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 12-29-2024, 08:11 AM   #11
glennpm
glennpm's Avatar
In my '32
Left to right:
- Temp
- Tach
- Oil pressure
- Voltage
- Vacuum
Rumble Seat’s Notes
