1949 Ford F-1 PU
Replaced fuel gauge and sending unit with new Bob Drake units. Note: The gauge cluster and tank are grounded. After replacement of both gauge did not work at all. Removed Drake unit and reinstalled original sending unit - gauge works, however, pulsates/fluctuates between Full and Half Tank reading I'm posting for a friend and he is seeking any assistance or thoughts on this matter. Thank you in advance. LouB. |
With fuel gauges and sending units, it is often easier to troubleshoot before fully installing the sender. Check the connections - both signal and power.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
Put an extra ground wire on one of the screws of the sending unit to see if that helps.
If so, this thread will be very helpful, especially post #3. https://www.fordbarn.com/forum/showt...k+sending+unit |
