49 Ford F-1 PU Fuel Gauge Question 1949 Ford F-1 PU
Replaced fuel gauge and sending unit with new Bob Drake units. Note: The gauge cluster and tank are grounded. After replacement of both gauge did not work at all. Removed Drake unit and reinstalled original sending unit - gauge works, however, pulsates/fluctuates between Full and Half Tank reading I'm posting for a friend and he is seeking any assistance or thoughts on this matter. Thank you in advance. LouB. |
Re: 49 Ford F-1 PU Fuel Gauge Question With fuel gauges and sending units, it is often easier to troubleshoot before fully installing the sender. Check the connections - both signal and power.
Re: 49 Ford F-1 PU Fuel Gauge Question Put an extra ground wire on one of the screws of the sending unit to see if that helps.
Re: 49 Ford F-1 PU Fuel Gauge Question Ford46: Hopefully your friend still has the OEM KS Gas Tank Sending unit.
If so, this thread will be very helpful, especially post #3. https://www.fordbarn.com/forum/showt...k+sending+unit |
| All times are GMT -5. The time now is 04:11 AM. |
