Old 10-21-2024, 06:29 PM   #1
Mark T
Default What is this on this Stromberg carburetor?
I bought this Stromberg at the Hershey swap meet and I have no idea what this is that’s mounted on it.
Mark T is offline   Reply With Quote
Old 10-21-2024, 06:38 PM   #2
51504bat
51504bat's Avatar
Default Re: What is this on this Stromberg carburetor?
Just a wild ass guess but a fitting for a gas heater? But I'm sure others will know for sure.
Old 10-21-2024, 06:42 PM   #3
Bob C
I was thinking the same, Southwind heater.
Old 10-21-2024, 10:11 PM   #4
alchemy
alchemy's Avatar
That is the Stromberg specific fuel siphon for a Southwind. The fitting is probably as valuable as the carb.
alchemy is offline   Reply With Quote
Old 10-21-2024, 10:15 PM   #5
tubman
tubman's Avatar
Is that sheet metal shield in front of the accelerator pump a standard Southwind part? Looks like a desirable safety feature to me, and probably harder to find than the fuel siphon.
Old 10-22-2024, 02:47 AM   #6
Mart
Mart's Avatar
Tubs, the bracket appears to be supporting the top part of the syphon device. So as such, it must be a southwind part.
Old 10-22-2024, 07:22 AM   #7
alchemy
alchemy's Avatar
Part of the mounting bracket. Not sure if it has another purpose though.
Old 10-22-2024, 10:04 AM   #8
V8guy
V8guy's Avatar
I have that set up on my 35 with a
Southwind heater works great
Mike
V8guy is offline   Reply With Quote
Old 10-22-2024, 10:15 AM   #9
1952henry
1952henry's Avatar
I have that same setup that came to me on a 94. Usually see a hole drilled in air horn above fuel bowl for a pickup tube. It has a special jet plug for fuel to be siphoned.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 10-22-2024, 09:22 PM   #10
alchemy
alchemy's Avatar
The extra hole in the top of many old carbs was drilled because they used the “universal” siphon kit.
Old 10-22-2024, 11:58 PM   #11
TonyM
TonyM's Avatar
Here is the set up I discovered on my Southwind equipped car the day I brought it home. I removed all that plumbing and run with no heater. The Southwind still resides in the car, but it is not hooked up.
TonyM is offline   Reply With Quote
Old 10-23-2024, 07:56 AM   #12
rockfla
rockfla's Avatar
Here you go!!!
Old 10-23-2024, 09:35 AM   #13
5851a
https://www.bing.com/videos/rivervie...85C3&FORM=VIRE
5851a is offline   Reply With Quote
Old 10-23-2024, 02:42 PM   #14
Mark T
Thanks to all that commented…
