#21 |
1930Artdeco,
After a good solvent cleaning in my parts washer, I spray the carb body with brake cleaner as a final cleaner because it because it removes any grease or oil films and dries without leaving any residue. Then painted with VHT gloss black engine enamel. |
#22 |
Been looking for a Marvel carb for my '31 but all I can come up with are carbs for tractors.
I have nothing against tractors, but I would like to use a carb specifically made for an old Model A banger. |
#23 |
Just put one on my 29,and so far I like it. Now I have to put heli coils on my spares mounting flange
#24 |
49topless I have a Marvel carb but with all my problems have yet to try it on my A. You mentioned that all you can find are Tractor carbs. Can you please tell me the difference between a car carb. and tractor carb. ?
I don't care if the "A" Starts BUT sure WANT IT TO STOP! |
#25 |
I am in.
#26 | |
The Master Cylinder Enjoying life at the beach in SoCal... |
#27 |
An acquaintance is so anal he copied and made his own Marvel Schebler decal for his Marvel.
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 09-28-2024 at 12:13 AM. |
#28 |
I am also in. I have been impressed by the improved performance of the Marvel over the Zenith or the Tilly.
#29 |
Count me in . Had my marvel for a couple of years ,no issues,much better performance than my Zeniths. I made a micarta ( fenolic ) spacer between carb and manifold, prevents heat soak down from intake manifold to carb, when engine shut down, helps to prevent fuel expansion and fuel drips.
Don S |
#30 |
I’m in. Already tried Zeniths, currently running a Tillotson, but I like the idea of more power. The pot metal body does not worry me.
David in San Antonio Late ‘30 Deluxe "Wretched Roadster" 1931 Slant Windshield Fordor “Earl Gray” Alamo A’s Club |
#31 | |
Here is an excelent thread from Ford Barn past on Marvel Schebler Carburetors. A lot of good information. https://www.fordbarn.com/forum/showthread.php?t=139836
Thanks for posting a picture of my Marvel Master Cylinder. Last edited by Y-Blockhead; 09-28-2024 at 04:32 PM. |
#32 | |
I am very unfamiliar with the Marvel carbs and I do not know if those used on tractors, are the same or different that the Marvels used on Model As. I'm trying to learn as much as possible about, what seems to be, a very good carb for my Model A. Thank you |
#33 |
Anybody have contact information on the place that sells rebuild kits for the Marvel-Shebler?
#34 | |
#35 |
I believe the tractor carburetors do not have the GAV adjustment provisions.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
#36 |
I put a quart bottle in my 80 gallon
diesel cross tank in my truck bed occasionally when I fill - it helps clean the tank and probably the diesel injectors as well . 1996 Ford F350 XLT 7.3 PSD CC 2WD w/ 4:10 rear diff & E4OD Jim |
#37 | |
Y-Blockhead... any chance those Marvel stickers might be available? I really like those |
#38 |
Here's a picture of the remains of an original Marvel decal.
Jeff |
#39 |
I have been running my Marvel for about 8 years.
I drove my A to our next town with the marvel. The drive is a steady 6 mile uphill run. My A screamed up the hill with the Marvel doing 55 in overdrive. I took the same drive with a brand new rebuilt Zenith. My A bogged down to 50 and I had to take the A out of overdrive to make the hill. Conclusion: The Marvel is a better carb than the Zenith on my A. JMO |
#40 |
I'm in. Have rebuilt a few and installed a few. One on the engine and one under the seat tuned to my car. Fun to offer a trial to someone that has not got theirs carb working, what ever it is, and see their smiles.
Paul H |
