Old 08-16-2024, 10:00 AM   #1
EAV8
Default K.R.Wilson. B.V. 20 Puller
I cannot find this tool in my (3) K R Wilson catalogs. Can anyone tell me the function and year it was used. Thanks
EAV8 is offline   Reply With Quote
Old 08-16-2024, 11:42 AM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: K.R.Wilson. B.V. 20 Puller
I had a KRW tool I could not identify also. It turns out Old KRW made tools for other makes. I had a very special tool for setting the end play on Packard crankshafts. There was a large "P" on the tool as well as the number. I donated it to a Packard club.
At first glance it looked like part of a Norden bomb sight!
Old 08-16-2024, 09:12 PM   #3
DavidG
DavidG's Avatar
BV-20 shows up in the K.R.Wilson catalogs in the 1930s. Its function is a steering sector arm puller.
Old 08-17-2024, 12:01 PM   #4
Strick
Strick's Avatar
do you have a picture?
1940 Mercury Coupe
1940 Ford Standard Business Coupe
Looking for Kurten - Spalding - Harman Collins - W&H Ducoil - Berk - Kong - Eddie Meyer dual coil converted dizzys
Strick is offline   Reply With Quote
Old 08-17-2024, 01:49 PM   #5
DavidG
DavidG's Avatar
From a K.R. Wilson catalog.
Old 08-17-2024, 03:35 PM   #6
Strick
Strick's Avatar
Thanks David! Is there an adapter cup next to the end of the sector shaft?
1940 Mercury Coupe
Old 08-17-2024, 05:32 PM   #7
DavidG
DavidG's Avatar
There's a cup there to center the threaded shaft of the tool and to protect the threads on the end of the sector gear shaft.
Old 08-17-2024, 06:02 PM   #8
34fordy
34fordy's Avatar
The one on fleabay is missing the protective collar.
34fordy is offline   Reply With Quote
Old 08-17-2024, 06:14 PM   #9
Strick
Strick's Avatar
Thanks David. I am missing that “cup” or “protective collar” if anyone has one.
1940 Mercury Coupe
Old 08-19-2024, 06:53 AM   #10
Terry,OH
Terry,OH's Avatar
may find a replacement in a new C-clamp, remove and fit to your BV20 then peen in place.
Old 08-23-2024, 09:19 PM   #11
Strick
Strick's Avatar
Thanks Terry
1940 Mercury Coupe
Old 08-24-2024, 07:32 AM   #12
Mart
Mart's Avatar
The original might have a small point on the adaptor to engage in the center drilling in the end of the pitman shaft.
Old 08-24-2024, 08:40 AM   #13
38 coupe
38 coupe's Avatar
The protector cup can be turned on a lathe, possibly the only easily remade part in the tool assembly.
Old 08-24-2024, 03:58 PM   #14
mercman from oz
mercman from oz's Avatar
K.R.W. Steering Arm Puller - DavidG
mercman from oz is online now   Reply With Quote
