K.R.Wilson. B.V. 20 Puller I cannot find this tool in my (3) K R Wilson catalogs. Can anyone tell me the function and year it was used. Thanks
Re: K.R.Wilson. B.V. 20 Puller I had a KRW tool I could not identify also. It turns out Old KRW made tools for other makes. I had a very special tool for setting the end play on Packard crankshafts. There was a large "P" on the tool as well as the number. I donated it to a Packard club.
At first glance it looked like part of a Norden bomb sight! |
Re: K.R.Wilson. B.V. 20 Puller BV-20 shows up in the K.R.Wilson catalogs in the 1930s. Its function is a steering sector arm puller.
Re: K.R.Wilson. B.V. 20 Puller do you have a picture?
Re: K.R.Wilson. B.V. 20 Puller 1 Attachment(s)
From a K.R. Wilson catalog.
Re: K.R.Wilson. B.V. 20 Puller Thanks David! Is there an adapter cup next to the end of the sector shaft?
Re: K.R.Wilson. B.V. 20 Puller There's a cup there to center the threaded shaft of the tool and to protect the threads on the end of the sector gear shaft.
Re: K.R.Wilson. B.V. 20 Puller The one on fleabay is missing the protective collar.
Re: K.R.Wilson. B.V. 20 Puller Quote:
Re: K.R.Wilson. B.V. 20 Puller may find a replacement in a new C-clamp, remove and fit to your BV20 then peen in place.
Re: K.R.Wilson. B.V. 20 Puller The original might have a small point on the adaptor to engage in the center drilling in the end of the pitman shaft.
Re: K.R.Wilson. B.V. 20 Puller The protector cup can be turned on a lathe, possibly the only easily remade part in the tool assembly.
Re: K.R.Wilson. B.V. 20 Puller |
| All times are GMT -5. The time now is 06:49 AM. |
