Your horn light rod may be from a later model Ford. Caution, if you need to remove the rod for modification, you'll need to drop the steering box to allow the rod to clear the tube when pulling, unless you have a roll-down rear window in that coupe? There is no shortcut here, the rod will bend if you try, and that's big trouble.
Alan |
