Old 01-16-2023, 04:46 PM   #1
olhkry
Default 1947 Hore Ring
Having trouble removing the horn ring on a 1947 Ford. I've tried WD40 and turning CCW after pressing on ring assembly. Any other pointers/suggestions?
olhkry is offline   Reply With Quote
Old 01-16-2023, 04:52 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: 1947 Hore Ring
You are attempting to do this correctly. Occasionally, moving it a bit clockwise, then counterclockwise helps.
Be careful pressing down. I'd suggest applying pressure very near the hub.
If I were to offer a guess, I'd suggest the foam rubber insulating ring directly below the hub is pretty much "melted" and acting as if it were glued to the hub.
Old 01-16-2023, 05:28 PM   #3
FortyNiner
FortyNiner's Avatar
Are you trying to remove the button or the ring?
Old 01-16-2023, 05:32 PM   #4
Kube
Super Moderator
Kube's Avatar
FortyNiner asks a good question... to clarify, the ring is integral of the button (hub).
Old 01-19-2023, 02:58 PM   #5
olhkry
Trying to get to the button under the ring. The horns work (removed and hotwired) but, when re-installed, they don't. It appears that the wire from the horn relay to the horn button has been pulled out.
Old 01-19-2023, 04:01 PM   #6
Kube
Super Moderator
Kube's Avatar
The entire assembly comes off as one piece. In other words, the stainless ring and spokes as well as the button.
Once you have this assembly removed, you will quickly see how the button is held in the ring. Easy to remove.
Old 01-19-2023, 04:48 PM   #7
Graeme / New Zealand
Graeme / New Zealand's Avatar
bit of advise. when pushing and turning anti clockwise, don't grab by the horn ring spokes only, cup one hand around the whole centre or you might bust a spoke or spokes, they are only made of diecast.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 01-19-2023, 04:58 PM   #8
olhkry
Thanks very much. Unable to get the steering wheel off, but got the emblem off and was able to establish complete circuit. Hopefully, horn will operate correctly once the connections are complete. Life and old cars are a mysterious journey.
Old 08-18-2024, 05:03 PM   #9
flathead47
flathead47's Avatar
I am having the issue getting the horn ring off my steering wheel as well.
It looks like the felt as Kube states has melted and is creating the problem.
Does anyone have a picture of what the is underneath when the ring/button assembly is off the wheel so I get a better feel how to move forward.
Thanks
flathead47 is offline   Reply With Quote
Old 08-19-2024, 10:09 AM   #10
deuce lover
deuce lover's Avatar
Look at this auction.Lots of pics including back side.
https://www.ebay.com/itm/276262656239
deuce lover is online now   Reply With Quote
Old 08-19-2024, 01:15 PM   #11
47fordguy
47fordguy's Avatar
Thanks
I don't have the insulator but here's some photos underneath.
No job is so important and no service is so urgent- that we cannot take time to perform our work safely.
-Bell System
47fordguy is offline   Reply With Quote
Old 08-19-2024, 01:58 PM   #12
flathead47
flathead47's Avatar
Thanks Deuce and 47 ,
that gives a good picture of what needs to be done to get it off.
I think I have one side off and the melted felt is holding the other side from allowing the ring to be fully lifted out.
Flathead47
Old 10-13-2025, 10:47 AM   #13
flathead47
flathead47's Avatar
Finally was able to get the horn ring off, but part of the assembly is damaged. Wondering if the broken ring can be replaced or do I have to get a whole new assembly.
Also it looks like the nut on the steering shaft is wrong , what is the would be the correct nut to use.att.c3ugHB4U3P88M01Azw3a6JroX5f3UuQNXSb51cVnKQo.jpg
Old 10-13-2025, 10:55 AM   #14
petehoovie
petehoovie's Avatar
Old 10-13-2025, 11:25 AM   #15
TJ
TJ's Avatar
That inner ring can be replaced. I'll bet somebody has a junk steering wheel around with that part on it. I think the inner ring is the same from '41 to '48. The nut looks correct to me.
Old 10-13-2025, 12:10 PM   #16
flathead47
flathead47's Avatar
Petehoovie, thanks for the enlarged pictures.
TJ, I wasn’t sure if the whole inner assembly had to be replaced as an assembly or if only the broken outer ring was available and then revited back on to the inner assembly.
Old 10-13-2025, 08:10 PM   #17
Joe B.
Joe B.'s Avatar
I finally got the ring to move on my '50 with heavy palm pressure on the hub and a couple light taps with a rubber hammer on the spoke near the hub.
thread killer
Joe B. is offline   Reply With Quote
Old 10-15-2025, 10:46 AM   #18
TJ
TJ's Avatar
Remove the three screws and the assembly comes out of the horn ring. It's been awhile since I took one apart, but I "think" the two pieces come apart. Once out you will be able to tell.
Old 10-15-2025, 10:58 AM   #19
rockfla
rockfla's Avatar
From the "Just Gotta" department
I am SO glad that there are SO many "HORN RING" experts on here and not "HORE RINGS" like the "Original Poster's Title" I would start to question who I am associating with IF it was reversed!!!!! Phonetically speaking
Old 10-15-2025, 12:08 PM   #20
tubman
tubman's Avatar
You really can't blame him. IIRC, you used to be able to change the title of a thread, but for some reason, that capability disappeared several years ago. Now, I double check everything before I hit "POST".
