#121 |
Yipes, is that semantics or grammer that invaded a compliment ?
#122 |
#123 |
We now have available new replacement starter cups for the truck 8RT-6392 bell housings. This is a brand new part made of steel that fits perfectly in the opening of the cast iron 8RT truck bell housings. Replace that damaged or missing cup. You can weld or glue the new cup into the place of the original cup, which was rolled/crimped into place by Ford. Protects your starter from road dust and water spray. Link to our website for these:
http://www.vanpeltsales.com/FH_web/e...prices-pg2.htm
VANPELT SALES LLC Cincinnati, Ohio Office: 513-724-9486 www.vanpeltsales.com www.classictransmission.com |
#124 | |
#125 |
We didn’t have a large quantity made for the first time….. wanted to see how they fit and get an idea of what the demand would be before we have more made. I’m very happy with the fit.
#126 |
#127 |
Hello Folks,
After always struggling to find good originals, I have decided to make the carpet retainer sockets for 1932 Fords, part no. 353109-S15. These are now available on my website or PM me here if you need more information. Don't forget to use discount code FORDBARN10 to save yourself 10% on any order. Thanks! |
#128 | |
#129 |
A few new items available:
1933-34 Ford rear transmission support https://thirdgenauto.com/product/193...mission-mount/ 1934 Ford Chrome plated grille https://thirdgenauto.com/product/new...chrome-plated/ 1932-36 Ford rear transmission support special "D" headed bolts https://thirdgenauto.com/product/193...olts-set-of-4/ |
#130 | |
Any chance you'll be making the special the smaller diameter headed castle nuts for the '32-'36 D headed bolts? Last edited by Tim Ayers; 06-12-2024 at 10:36 AM. |
#131 | |
https://thirdgenauto.com/product/192...ouldered-nuts/ |
#132 | |
Ah, got it. The difference in length is for the cast vs stamped couplers, right? |
#133 |
#134 |
OldGold360,
Any chance that you'll be making the capped studs used with floor mats and your sockets? Your sockets were also used on '33-'34 V8 passenger car #1 wood floor boards. |
#135 | |
I am hoping to. I have some good originals to use, I just need to find the time to figure out how best to make them. I did just finish up everything I needed to do to be able to accurately reproduce the ‘32 floorboards and I will always have them in stock, unless they stop making nice plywood. I am currently working on finishing up a couple of other pieces. When those are finished, I will look at reproducing those capped studs. I’ll share some updates here when that time comes. Till then, here are some pictures of the ‘32 Floorboards. |
#136 |
Your boards look great!
#137 | |
#138 |
Just fabulous !!
#139 |
#140 |
