Old 06-05-2024, 06:35 AM   #1
Bruce in southern OH
Bruce in southern OH's Avatar
Default 1940 coupe front drivers side brake flex line removal
What needs to be done to remove drivers side brake flex line from wheel cylinder to the brass tee. Mine looks like there is no swivel fitting into the brass tee. Appreciate info, Bruce
Bruce in southern OH is offline   Reply With Quote
Old 06-05-2024, 07:46 AM   #2
fordyford
fordyford's Avatar
Default Re: 1940 coupe front drivers side brake flex line removal
The brass tee is a banjo fitting. Take out the bolt that goes through it.
fordyford is offline   Reply With Quote
Old 06-05-2024, 09:09 PM   #3
Thank you, got that done today, rebuild two front wheel cylinders tomorrow, Master cylinder flush and lines. My son is coming over and will get me back in the photo business again.
Old 06-06-2024, 10:20 AM   #4
19Fordy
19Fordy's Avatar
Well done. Always take dated photos to document what you have done to maintain, repair and replace regarding the work you do on your car.
