1940 coupe front drivers side brake flex line removal What needs to be done to remove drivers side brake flex line from wheel cylinder to the brass tee. Mine looks like there is no swivel fitting into the brass tee. Appreciate info, Bruce
Re: 1940 coupe front drivers side brake flex line removal The brass tee is a banjo fitting. Take out the bolt that goes through it.
Re: 1940 coupe front drivers side brake flex line removal Thank you, got that done today, rebuild two front wheel cylinders tomorrow, Master cylinder flush and lines. My son is coming over and will get me back in the photo business again.
Re: 1940 coupe front drivers side brake flex line removal Quote:
| All times are GMT -5. The time now is 10:17 PM. |
