Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 05-06-2010, 07:53 AM   #1
Ryan
Administrator
Ryan's Avatar
Default Are you getting a "Security Token Error?"
If so, please excuse it... It's a bug. Typically you get that error when uploading images. It just means that the images you are uploading are too large in file size.
Ryan is offline   Reply With Quote
Old 10-20-2013, 07:09 PM   #2
jimvette59
jimvette59's Avatar
Default Re: Are you getting a "Security Token Error?"
Yes but it states that it will re size the pictures to fit.
jimvette59 is offline   Reply With Quote
Old 12-20-2013, 07:05 PM   #3
transbytip
Ryan I left a p.m. no answer how do you down size pics to post thanks transbytip
transbytip is offline   Reply With Quote
Old 03-21-2014, 10:26 AM   #4
sahsuvaroglu
Thanks for the reply..
Ford
sahsuvaroglu is offline   Reply With Quote
Old 10-13-2014, 01:56 PM   #5
ottosautos
Hi Ryan
How do you downsize file size.....been getting security token errors???
Any tutorial to review..??
ottosautos
[email protected]
ottosautos is offline   Reply With Quote
Old 07-10-2017, 03:57 PM   #6
VeryTangled
VeryTangled's Avatar
Windows users... Open your photo with PAINT (right-click, Open With...), then use the resize feature, after sizing, save as a new file and you have both sizes. I usually select the pixels, and just set one dimension, the other dimension sets itself and the photo stays in the same aspect ratio.
BTW this works with the upside down photos that come from my smartphone, I use PAINT to rotate them.
-Jeff H
