Are you getting a "Security Token Error?" If so, please excuse it... It's a bug. Typically you get that error when uploading images. It just means that the images you are uploading are too large in file size.
Re: Are you getting a "Security Token Error?" Yes but it states that it will re size the pictures to fit.
Re: Are you getting a "Security Token Error?" Ryan I left a p.m. no answer how do you down size pics to post thanks transbytip
Re: Are you getting a "Security Token Error?" Thanks for the reply..
Re: Are you getting a "Security Token Error?" Hi Ryan
How do you downsize file size.....been getting security token errors??? Any tutorial to review..?? ottosautos [email protected] |
Re: Are you getting a "Security Token Error?" Windows users... Open your photo with PAINT (right-click, Open With...), then use the resize feature, after sizing, save as a new file and you have both sizes. I usually select the pixels, and just set one dimension, the other dimension sets itself and the photo stays in the same aspect ratio.
BTW this works with the upside down photos that come from my smartphone, I use PAINT to rotate them. |
| All times are GMT -5. The time now is 11:20 AM. |
