Old 01-09-2024, 11:30 AM   #1
Jeep09
Jeep09's Avatar
Default Remote oil filter- fill before install
I have the MCF Mark Kirby remote filter setup, installing in truck now, motor has been pre-run. Should the filter be pre filled or not. I remember reading about this...anyone know. Thanks
Jeep09 is offline   Reply With Quote
Old 01-09-2024, 01:34 PM   #2
V8 Bob
V8 Bob's Avatar
Default Re: Remote oil filter- fill before install
Mark always advised me not to pre-fill the filter with his full flow system, and frankly I never saw much time difference with oil pressure rise either way. What I tried years ago is remove the input AN fitting to the filter mount and connect my flathead engine pre-oiler, a simple 1 gallon garden sprayer with engine oil. Now, the filter is filled correctly, and pressure rise time is much less! I perform this after oil/filter changes on my FE powered '40 which also has a remote filter.
Old 01-09-2024, 02:12 PM   #3
Jeep09
Jeep09's Avatar
my filter is up above the drivers side cylinder head about 8” mounted to firewall . 1/2 AN line
from pan to filter /1/2 return
Old 01-09-2024, 02:13 PM   #4
Ronnieroadster
Ronnieroadster's Avatar
Any remote filter conversion I add to Ford flathead projects I always prefill the filter and recommend this to anyone using a remote conversion. Heck I always do the same on all of my daily drivers as well.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 01-09-2024, 02:27 PM   #5
glennpm
glennpm's Avatar
I prefill all my oil filters, air too :-)
Old 01-09-2024, 02:27 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Ronnieroadster
Is there ANY good reason NOT to pre-fill a filter? I've been doing that since I was a snot-nosed kid and I haven't lost an engine yet as a result of oil starvation.
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 01-09-2024, 06:07 PM   #7
tubman
tubman's Avatar
I have to agree with the above three guys; I can't think of any reason not to.
Old 01-09-2024, 06:23 PM   #8
flatford8
flatford8's Avatar
I’ll join this club…..on daily drivers with a horizontal filter, I put in some and screw the filter on real quick…..ok so, where’s that guy from who prefils his air filter…LOL…..Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 01-10-2024, 12:06 AM   #9
RalphG
RalphG's Avatar
I've been changing oil, both engine and transmission /hydraulic for over 50 years and never pre-filled one yet. Never harmed an engine yet either.
RalphG is offline   Reply With Quote
Old 01-10-2024, 08:13 AM   #10
glennpm
glennpm's Avatar
Talking Re: Remote oil filter- fill before install
Must be another Mainer :-)
Glenn
Old 01-10-2024, 08:33 AM   #11
glennpm
glennpm's Avatar
On my '32, I mounted the horizontal filter with a quick release system so that I can fill the filter vertically and then mount horizontally.
Old 01-10-2024, 11:07 AM   #12
deuce_roadster
deuce_roadster's Avatar
I know he is gone, but the people I know who actually knew him told me that Kirby was more of a salesman than machinist/mechanic. I too cannot fathom why anyone would tell people to NOT prefill an oil filter unless he installed them upside down.
Old 01-10-2024, 12:46 PM   #13
jeepguy1948
The only reason that I have ever hear (and I think it’s ridiculous) is that the oil poured into the filter would not be filtered. Seriously, you would worry about 8-12oz of brand new oil not being filtered??? My own belief is that if there is not a reason (other than convenience) to NOT pre fill then do it if it makes you warm and fuzzy inside
jeepguy1948 is offline   Reply With Quote
Old 01-10-2024, 01:54 PM   #14
V8 Bob
V8 Bob's Avatar
I knew Mark for 25 years and think your remarks about him are totally out of place. He isn't around to explain his beliefs, so lets keep the "I know a guy" crap out of here.
As I already stated, pressurizing the new filter was the best method I've found to minimize the oil pressure rise time on my remote filter installations, as that's what the OP was initially asking about.
PS-I've always prefilled vertical block-mounted filters.
Old 01-10-2024, 01:59 PM   #15
deuce_roadster
V8 Bob- I never said I knew the guy and explained it was second hand info.
I apologize if I hurt your feelings.
Old 01-10-2024, 02:03 PM   #16
69a
The reason given to me was that if you prefill your filter you risk getting an air lock in your oil pump. Because after an oil change, you have to displace about 4oz of air on the intake side of the pump. Therefore if you have prefilled your filter there can be too much resistance on the upstream side. I was having issues with my 100% MCF system, but turned out to be the incorrect dipstick meaning I was about 2 quarts low.
So now I never bother prefilling, just do your oil change with the engine warm, and start the engine soon after, and make sure you get pressure.
69a is offline   Reply With Quote
Old 01-10-2024, 02:10 PM   #17
V8 Bob
V8 Bob's Avatar
That's what I meant about "I know a guy", but we're good, so thanks.
Old 01-10-2024, 02:12 PM   #18
V8 Bob
V8 Bob's Avatar
I had forgotten the details and didn't want to bring it up, but thanks for explaining Mark's reason.
