Old 06-08-2011, 09:53 PM   #1
Mark63
Mark63's Avatar
Default Anit-Rattler Installation
What is the best/easiest way to install the anti-rattlers in a 1930 Model A?
Mark63 is offline   Reply With Quote
Old 06-08-2011, 10:07 PM   #2
Pilotdave
Pilotdave's Avatar
Default Re: Anit-Rattler Installation
Disconnect rear rod clevises; loosed locking nuts and remove clevises; slide anti-rattlers over rods so that they are pushing against donuts toward rear of car; bolt to bracket on radius rods; reinstall clevises and locking nuts. Fronts are different - anti-rattlers slide on from eye end of brake rods, so disconnect from cross-shaft arm at center of car, slide anti-rattler on, bolt to bracket; reconnect rod at center. You may have to enlarge the openings in the front anti-rattlers so they will slide over the eyes.
Pilotdave is offline   Reply With Quote
Old 08-10-2024, 04:38 PM   #3
deb43cat
Which way are the front brake flat spring type anti-rattlers supposed to point in s brake off mode? Does the open end of the cup face fornt or back?
deb43cat is offline   Reply With Quote
Old 08-10-2024, 05:07 PM   #4
Synchro909
Synchro909's Avatar
For both front and back, the open face of the spring are against the bulge in the brake rod and are trying to push it in the opposite direction to the one in which it moves when you apply the brakes.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 08-11-2024, 02:44 PM   #5
johnbuckley
johnbuckley's Avatar
Do the anti rattlers fit in front or behind the frame bracket, and why? - or doesn't it matter?
Old 08-11-2024, 05:00 PM   #6
JayJay
RG&JS doesn’t specify. Just be sure that where you mount them, you get a good pressure away from the cross shaft.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 08-11-2024, 06:10 PM   #7
JayJay
Duplicate deleted
JayJay
Old 08-12-2024, 10:57 AM   #8
Bob Bidonde
Bob Bidonde's Avatar
Here are some tips to prevent rattles and assure the brake rods return.
File Type: jpg Brakes, Service - Return Addition 266kb.jpg (73.8 KB, 26 views)
Bob Bidonde
