Old 02-27-2023, 07:09 PM   #1
GaryU.
GaryU.'s Avatar
Default "NEW" in the garage,Laboratory Test Set
Got this about six weeks ago in South East Iowa. Accidentally came across the listing on C-List 23 minutes after it was listed. Called right away and after a few days made the deal. Earlier Model using a six volt battery to operate, Newspaper in the battery area dates to 1959! Looks like it was used quite a bit over the years and has wear one would expect for something this old. Will be using this as a conversation piece in the basement rec room, no plans to restore or even attempt to use! When bringing it home in an enclosed trailer laying on it's back many screws,washers and extras migrated into neat piles in the trailer!
File Type: jpg 2266739B-5CDF-45F3-A9BA-829E4909C539_1_201_a.jpg (58.4 KB, 468 views)
File Type: jpg 8CEE0B23-6B7A-42C5-AD0B-2A1E18C2380E_1_201_a.jpg (72.4 KB, 451 views)
File Type: jpg D7584623-16B0-482B-8692-EB4E69718001_1_201_a.jpg (82.7 KB, 94 views)
File Type: jpg 866E888E-E013-4088-85C5-A9A1705407D6_1_201_a.jpg (74.9 KB, 312 views)
File Type: jpg 7503AB35-1079-4991-BE3D-3A19131E5B4A_1_201_a.jpg (67.5 KB, 88 views)
File Type: jpg D5836329-A7F6-491F-B3DF-3F914449B391_1_201_a.jpg (60.4 KB, 442 views)
File Type: jpg D4695E7F-F748-49D4-A7A1-F2607ABDB321_1_201_a.jpg (62.0 KB, 91 views)
File Type: jpg AF49E2E7-83F9-42CB-84A9-9C00A53F5DE2_1_201_a.jpg (72.7 KB, 87 views)
File Type: jpg E16341DA-3385-411B-B298-ABE834A5286A_1_201_a.jpg (44.4 KB, 89 views)
File Type: jpg B8E9041C-D886-434D-A6B3-A0510F2B7073_1_201_a.jpg (69.8 KB, 87 views)
File Type: jpg 023990D5-6A2D-44D5-8B2A-0E12F3F22E14_1_201_a.jpg (39.4 KB, 82 views)
File Type: jpg F970FDC4-6B44-49A2-BC68-2F8F5538C954_1_201_a.jpg (52.3 KB, 83 views)
File Type: jpg C7ABE740-2091-4510-B9C3-83113B090518_1_201_a.jpg (42.7 KB, 80 views)
File Type: jpg A28C96BB-15C9-400A-94A9-D37020075A1E_1_201_a.jpg (59.7 KB, 81 views)
File Type: jpg 5DE978A7-028E-4067-8B9E-B22CD75F0993_1_201_a.jpg (56.1 KB, 81 views)
GaryU. is offline   Reply With Quote
Old 02-27-2023, 07:17 PM   #2
petehoovie
petehoovie's Avatar
Default Re: "NEW" in the garage,Laboratory Test Set
Old 02-27-2023, 07:45 PM   #3
KDL
KDL's Avatar
That thing is beautiful! Quite the time capsule.
KDL is offline   Reply With Quote
Old 02-27-2023, 07:46 PM   #4
cas3
Pretty cool ! Now you need a lab coat
cas3 is online now   Reply With Quote
Old 02-28-2023, 08:02 AM   #5
corvette8n
corvette8n's Avatar
+1 a period correct Ford coveralls
Old 02-28-2023, 07:11 PM   #6
Ggmac
Love it ! Nice find . I rediscovered an old Heath oscilloscope and a champion scope . Both work . It would be interesting if that could be put back in service, at least partially.
Old 02-28-2023, 07:35 PM   #7
petehoovie
petehoovie's Avatar
Love the meter movements!...
Old 03-01-2023, 08:43 AM   #8
maineford
the guages are a kr wilson piece
maineford is offline   Reply With Quote
Old 03-01-2023, 08:58 AM   #9
Juergen
Nice find, Gary. A lot better than the ones I had. They came with an instruction book but a lot of the directions can be found in the Service Manual reprint books.
Juergen is offline   Reply With Quote
Old 03-01-2023, 09:05 AM   #10
sidevalve8ba
sidevalve8ba's Avatar
Kind of reminds me of a vacuum tube tester that was at a now defunct local chain drug store.
sidevalve8ba is offline   Reply With Quote
Old 03-01-2023, 02:05 PM   #11
Cecil/WV
Cecil/WV's Avatar
He can get one at the Early Ford V8 Museum in Auburn.
Cecil/WV is offline   Reply With Quote
Old 03-01-2023, 06:16 PM   #12
GaryU.
GaryU.'s Avatar
No instruction book but in a tray on the right side there are dozens of cards for the test procedures. Older ones have a 1935 Copyright, ones in the back half are dated 1939. As far as radio vacuum tubes, yes it did test those also, which explains the similar appearance.
Old 03-01-2023, 11:29 PM   #13
Don Rogers
Don Rogers's Avatar
There was a non-Ford instruction book for the Heyer Test set. Very informative with step by step instructions.
File Type: jpg Laboratory Tests For Ford Cars Early 1937 small-1.jpg (70.3 KB, 88 views)
Don Rogers is offline   Reply With Quote
Old 03-02-2023, 10:48 AM   #14
Zeke3
Zeke3's Avatar
You know, in all the time I spent reading the comic books at our local pharmacy back then, I do not remember seeing anyone testing their tubes in that tester.
Zeke3 is offline   Reply With Quote
Old 03-02-2023, 11:08 AM   #15
Tim Ayers
Love the tube testers on the left hand side.
Old 03-02-2023, 12:18 PM   #16
petehoovie
petehoovie's Avatar
Old 03-02-2023, 01:49 PM   #17
Don Rogers
Don Rogers's Avatar
If you are planning to restore nd use your test set, I would recommend looking for the strobescope attachment that allows you to set up your distributors off the engine.
Old 03-02-2023, 03:17 PM   #18
petehoovie
petehoovie's Avatar
