Old 12-15-2022, 04:32 PM   #11
Model51
Model51's Avatar
Default Re: BIG SHOCK on display engine
Lawson, since it's your project and you are paying you should do whatever makes you happy.
I've a good luck creating a Word document with a font which looks good. Then I had it printed at the local copy shop on high quality cardstock. Then I made a thin clear plastic cover the same size as the certificate and drilled small holes in the corners. Got the plastic (acrylic actually) sheet at the hardware store. Punched matching holes in the paper and used fancy brass screws to fasten the paper and cover to a slightly larger peice of walnut. This made a very nice certificate. Just an idea for you to consider.
Model51 is offline   Reply With Quote
