Old 11-04-2022, 05:43 PM   #1
mikesvintagecars
Default 1934 Ford 1 1/2 ton Truck Tires
Hello new to barn just purchased a 1934 model bb truck that has been in a barn since 1951 . anyone have any thoughts on tires for it? Too many choices any input appreciated Thanks
mikesvintagecars is offline   Reply With Quote
Old 11-04-2022, 06:15 PM   #2
sugarmaker
sugarmaker's Avatar
Default Re: 1934 Ford 1 1/2 ton Truck Tires
Mike,
I like the 6.00-20 Firestones on my ton and half. I got mine from Miller, but that was a year ago. Tubes and flaps were from Lucas. Hope that helps a little.
Interesting story. Mine was put away in 1952. I guess these are still out there!
We need some pictures!
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
1965 Mercury Comet Caliente
1966 Ford F100
2015 Ford F250 SuperCrew
Lots of Allis tractors
Some Cub Cadets
Old 11-04-2022, 06:16 PM   #3
mikesvintagecars
Thanks will be posting pics progress ect as soon as I figure this site out..Thanks Chris
Old 11-04-2022, 06:35 PM   #4
mercman from oz
mercman from oz's Avatar
Here is a picture of a 1934 Ford V8 Panel Delivery.
Old 11-04-2022, 06:40 PM   #5
mercman from oz
1934 Ford Panel Delivery from the Sales Brochure
Old 11-04-2022, 06:50 PM   #6
mercman from oz
1934 Ford Panel on 131.5 Inch Wheelbase
Old 11-04-2022, 07:37 PM   #7
Newc
Newc's Avatar
Note: you DO NOT want the rear duals so large that they rub sidewalls on the lower or loaded position-fronts can go larger, but then you have turning rubs. Newc
Old 11-04-2022, 07:42 PM   #8
GB SISSON
GB SISSON's Avatar
Hi Mike, Welcome to the Barn from a fellow Washingtonian. Awful wet tonight over here on the Left Side. Sounds really interesting what you have found. My advice is to read through Sugarmaker's thread, 'The Duece, the dually and the Dump Truck'. And of course keep in mind we all like pictures!
Old 11-04-2022, 08:46 PM   #9
Model51
Model51's Avatar
Mike,
Welcome and good luck with your truck. I have a 1935 1-1/2 ton truck and had the same questions about what tires to purchase. I decided the 6.00 x 20 were a bit skinny for my taste and the 7.00 and 7.50 x 20 are bit too large so I settled on 6.50 x 20. Unless you plan to carry heavy loads, it's more of a style question than a functional one, with the exception that larger tires are not only larger in diameter they are wider so clearance can be an issue. I purchased mine from Coker Tires a while back but Miller in Ohio is another good source. Tires for your truck are stlll being made but you might have to wait a bit to get the size any type (Firestone for example). Feel free to PM me if you want more detailed information.
Dave
Model51 is offline   Reply With Quote
Old 11-05-2022, 08:29 AM   #10
sugarmaker
sugarmaker's Avatar
Mike,
Here is a shot of the 6.00-20 Firestones:
I can get close up if you need them:
I choose these only becasue that was what was on the truck when I got it.
Another consideration. The spare I put on only allows me to open the passenger door about 50%.
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
1966 Ford F100
Some Cub Cadets
Old 11-06-2022, 08:52 AM   #11
mikesvintagecars
That makes sense I like your ideas, I think the 6.50 20 is a good choice great info Thanks
Old 11-06-2022, 09:00 AM   #12
mikesvintagecars
Default Re: 1934 Ford 1 1/2 ton Truck Home from 70 year sleep
Purchased this truck from a farmer this was his dads truck. parked in 1951 in barn, then in 1995 they moved it to another building where the truck was driven into till now, they changed oil stored it properly. The engine rolls over and has clean oil. Truck is in my shop and this is my winter project.
Old 11-06-2022, 09:01 AM   #13
mikesvintagecars
Thanks. My spare is in back. thanks for the info.......Mike Nice truck
Old 11-06-2022, 11:37 AM   #14
sugarmaker
sugarmaker's Avatar
Mike,
Awesome truck! Thanks for the pictures! Your going to have some fun with that unit!
Keep us up to date on your progress.
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
1966 Ford F100
Some Cub Cadets
Old 11-07-2022, 01:31 AM   #15
OldDad
OldDad's Avatar
Just today mounted up a pair of Lucas 600-20 tires (from Lucas tire in Long Beach CA) for the front of my buddy's '39 1-1/2 ton. Would have preferred the 650-20 Firestones, but at about $115 cheaper each, they'll do. Can't speak to their relative quality, however, having not run them yet. They are made in Vietnam, the tubes from India, but the flaps are made in USA, of all places!
OldDad is offline   Reply With Quote
Old 11-07-2022, 08:14 PM   #16
mikesvintagecars
Crazy......Yes I think im going with the 6.50 x 20 will be shopping for prices soon......Thanks
Old 11-07-2022, 08:40 PM   #17
sugarmaker
sugarmaker's Avatar
Sounds good!
I like the new shoes on my ragged ol truck! Some people think they are original. I drive on some dirt roads to get them looking right!
If those rims are similar to mine. Split type. Have them take care removing the split seal bead.
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
1966 Ford F100
Some Cub Cadets
Old 11-07-2022, 09:35 PM   #18
totto
totto's Avatar
I have a 1937 1 1/2 Ton dump truck(131WB) with 6.50 x 20's (new tires), Firestones, and the truck has 37,000 miles. I have the "original" spare tire which is a 6.00 x 20(Goodyear). I like the "bigger" 6.50 but these truck came with either 6.00 or 6.50 x20. I agree with Dave as the 6.00 are too skinny. Henry
totto is offline   Reply With Quote
Old 11-07-2022, 09:58 PM   #19
petehoovie
petehoovie's Avatar
Happy Guy Mike !!!
