Old 08-23-2022, 12:36 PM   #1
swedishsteel
Default merc crank on craigslist
reground merc crank on Fargo, ND craigslist auto parts for $200. Not mine and no connection to it.
swedishsteel is offline   Reply With Quote
Old 08-23-2022, 01:07 PM   #2
40cpe
40cpe's Avatar
Default Re: merc crank on craigslist
https://fargo.craigslist.org/pts/d/d...521788229.html
I would be wary at that price.
Old 08-23-2022, 01:31 PM   #3
petehoovie
petehoovie's Avatar
Old 08-23-2022, 09:49 PM   #4
19Fordy
19Fordy's Avatar
That's a super duper deal if it's good. Of course, you would have to go there and "mike" it yourself. I bet the shipping alone would be about $100.
Old 08-23-2022, 11:49 PM   #5
tomcarman
tomcarman's Avatar
Question for everyone. Is "1CM" as pictured in Pete's post #3 the definitive ID for a Merc crank? I have what I believe to be a Merc block that looks to be in good shape by the eye and several cranks. I'd like to find out if one of those cranks is for that block. I believe the block is a 39-42. It has markings on it and a "99" stamped on it. I can post pics if anyone is interested. Looking to sell.
Tom
tomcarman is offline   Reply With Quote
Old 08-23-2022, 11:53 PM   #6
cas3
Just eyeballing the picture it looks to have the large cleanout plugs, and if its been ground already its a good buy.
Old 08-24-2022, 02:07 AM   #7
tubman
tubman's Avatar
I believe that "1CM" designates a crankshaft from '51 up that has provision for the "Merc-O-Matic" transmission. The earlier crankshafts would be marked "8CM".
Old 08-24-2022, 06:38 AM   #8
Tim Ayers
There are a few different 4" cranks out there. Some of the Canadian 4" cranks have a "kidney bean" dimple on the front throw, so there are few different ways to tell. Easiest and surest way to tell is if the heavy bob weight is slightly over 6". If it's 5 1/2", its a 3.75" crank.
Old 08-24-2022, 08:45 AM   #9
pistonbroke
I was always told the 7/16" welsh plugs indicated 4" stroke. Have I been mislead ?
Old 08-24-2022, 12:25 PM   #10
Tim Ayers
That is also a good way to tell. The counter weight measurement is the most absolute way to tell.
Old 08-24-2022, 12:55 PM   #11
vincent
I would just measure the stroke
vincent is offline   Reply With Quote
Old 08-24-2022, 01:16 PM   #12
Mart
Mart's Avatar
More like 5/8" ain't they?
And I think 3/8" on the 3.75" cranks.
Old 08-24-2022, 01:17 PM   #13
Mart
Mart's Avatar
It's hard to measure the stroke of a crank on the ground.
Old 08-24-2022, 01:23 PM   #14
Tim Ayers
Correct. Large bob weight is the tell tale. Over 6", 4" stroke. Around 5.5", 3.75 stroke.
Old 08-24-2022, 03:48 PM   #15
tubman
tubman's Avatar
What part of "1CM" stamped on the counterweight don't you understand?
Old 08-24-2022, 04:16 PM   #16
Tim Ayers
We're not just talking about this unit. Someone asked how to identify one out in the wild. We are just offering suggestions on how to do it.
Old 08-24-2022, 05:56 PM   #17
Flathead
Flathead's Avatar
The CM part denotes a Merc crank. The block is the same as a Ford, and 49 to 53 are the years for the 4" stroke.
If that crank measures out and isn't cracked it is a great deal.
Flathead is offline   Reply With Quote
