Old 08-17-2022, 09:27 AM   #1
Tim Ayers
Default Is it worth saving an empty trans case and bell housing?
I recently took in some parts. In the stash, was a model A trans. I offered it for sale complete, but had no takers. I took the gears out and sold them.
My space is limited and my question is it worth saving the empty case, top, & bellhousing? All parts are greasy, but rather nice. The case seems perfect.
I was planning on bringing them to Hershey and selling them cheaply, but I'd rather not lug around stuff that isn't going to sell.
Thoughts?
Please note, I hate scrapping parts, but I'm also a realist and want to avoid an ever increasing parts stash.
Old 08-17-2022, 10:26 AM   #2
alexiskai
alexiskai's Avatar
Default Re: Is it worth saving an empty trans case and bell housing?
I'm told it's rare to find a bell housing that isn't cracked, so if yours is in good shape, there's a market for it.
Old 08-17-2022, 10:44 AM   #3
old ugly
old ugly's Avatar
i think the tranny case if it is the later style would be a core for the place that does the syncro conversions. fyi the later style case would have had no shims on the cluster gear.
i have given lots of stuff away because it is too hard to deal with idiots over a low priced item.
i advertise and then sit stuff in the alley. first come first serve. i don't like wasting my time over a two bit item either.
that way the stuff gets used and doesnt impact me.
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 08-17-2022, 10:49 AM   #4
Tim Ayers
Thank you. Can you tell me where they generally crack so I can look?
Old 08-17-2022, 10:50 AM   #5
Tim Ayers
Thank you. It is the later style then. It had no shims.
Old 08-17-2022, 10:55 AM   #6
alexiskai
alexiskai's Avatar
I'm sorry, turns out it's the flywheel housing that frequently cracks. Never mind.
Old 08-17-2022, 10:58 AM   #7
Tim Ayers
I may not be calling to the right thing. The part I am calling a "bell housing" is the part that bolts to the front of the trans, the pedals hang on them from the shaft and it has the cross shaft for the clutch release.
In the Model A world, is that the flywheel housing? I'm a V8 guy, so I'm still learning Model A's.
Old 08-17-2022, 11:14 AM   #8
katy
katy's Avatar
A empty transmission case makes a good doorstop.
Old 08-17-2022, 11:15 AM   #9
Tim Ayers
Haha. Is a good complete top worth lugging around?
Old 08-17-2022, 11:20 AM   #10
alexiskai
alexiskai's Avatar
Yeah, that's the bell housing. The flywheel housing has the engine mount surfaces on each side and a hole for the starter. It's part of the engine, it wouldn't be on a transmission.
Old 08-17-2022, 11:24 AM   #11
Tim Ayers
Got it. Thank you. Are bell housings worth selling cheap or is it scrap fodder?
Old 08-17-2022, 12:10 PM   #12
J Franklin
J Franklin's Avatar
If you are thinking of scrapping it, why not just offer it free to the hobby? There should be someone wanting the parts. Mitchell overdrive company is the one that may need the trans case.
Old 08-17-2022, 01:46 PM   #13
jak
I cannot tell you how many transmission cases and bell housing's i've sent to the scrapper. They are like rabbits every collection i buy has 2,3,4 or more of each. I pick through them and keep the best to try sell them to anybody looking. But even at that i have a stack of bell housings 3-4 feet tall and at least one pallet of empty transmission cases. Even trying to give them away i've had no luck. And because of the weight and the size of the box required nobody wants to pay the shipping.
jak is offline   Reply With Quote
Old 08-17-2022, 02:46 PM   #14
ronn
scrap it Tim. I tried giving away a complete rear, drums brakes and all-guy only wtd a certain model/year. yes it was free.
got 20. at the syracuse scrapper. didnt want to do it, but dont have 3 yrs to sell it.....
Old 08-17-2022, 02:48 PM   #15
jack backer
Hold a flywheel housing with one finger, tap it with a wrench if it rings it’s good, if it clanks it’s cracked.
Empty A case and bellhousing? nobody pays up for anything…don’t agonize,scrap it
jack backer is offline   Reply With Quote
Old 08-17-2022, 04:02 PM   #16
daveymc29
daveymc29's Avatar
Try Mitchell's in Williams, CA. The want a core for building the syncro tranny. Sure they'd like to have it if it is good, the tower also maybe?
I have stitched up a few of the flywheel covers. Not sure how good they were but the didn't ring like an uncracked one. If yours will ring when suspended on a wire and gently struch with a wrench that should indicate no cracks. New ones are around $500. If throwing away, bear that in mind. Points restorer guys like originals. (Cracked ones make a "thus" sound, no ring.
daveymc29 is offline   Reply With Quote
Old 08-17-2022, 04:40 PM   #17
JBill
I only discard Model A parts if I know they are being reproduced by reputable folks, and even then only when they are in very rough condition. Pretty sure bell housings and trans cases are not! Someday someone might be very glad to have them.
JBill is offline   Reply With Quote
Old 08-17-2022, 06:28 PM   #18
Tim Ayers
If I get time to de-grease them, I'll bring them to Hershey. I'll ask $5.00 a piece. Of course, everything is negotiable at Hershey.
Old 08-17-2022, 07:42 PM   #19
Synchro909
Synchro909's Avatar
I makes me cry to hear you guys telling someone to scrap those things. I grab every part, even gearbox cases and bell housings when I can - especially bell housings. RHD ones are not so easy to find and many are damaged and worn around the A frame ball socket. As for sending a complete rear end to scrap - that would never happen here but for me to even take it for free, it would be expensive by the time I got it home. Why don't you guys move a little closer!!!
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 08-18-2022, 08:12 AM   #20
Tim Ayers
I'll throw this out there. If anyone wants the case and bellhousing, come pick them up. I'd be happy to pass them along to someone who can use them.
