Old 07-19-2022, 04:25 PM   #1
Mart
Mart's Avatar
Default 4 speed + OD on a flathead in a 32. UNCUT K member. Can it be done? New project.
In this video I introduce my new project. I am going to fit a Volvo M410 transmission with overdrive in my 1932 Ford. The one stipulation is that I don't want to cut the original K member. It will be a long series, but hopefully a fun one to follow. So sit back and join me for part 1. Thanks for joining me once again in Mart's Garage.
https://youtu.be/p9lS0kmOdVA
Old 07-19-2022, 07:54 PM   #2
Robz51
Robz51's Avatar
Default Re: 4 speed + OD on a flathead in a 32. UNCUT K member. Can it be done? New project.
Looking forward to this one Mart!
Good luck!
Rob
Sent from my SM-G960U using Tapatalk
Robz51 is offline   Reply With Quote
Old 07-20-2022, 06:21 AM   #3
Mart
Mart's Avatar
Cheers Rob. I really set myself a challenge on this one!
Old 07-20-2022, 06:39 AM   #4
chuck stevens
chuck stevens's Avatar
pictures from j3 146.jpgMart, My A/V8 has a saginaw 4speed with a borg warner planetary overdrive. The o/d is actuated by a 12 volt solenoid like the 40's and 50's fords. The o/d main shaft excepts the 4 speed gears. I made an adapter and used 8ba BellhouseIng , flywheel and pressure plate, GM clutch. Sounds scary but this trans works perfect, 8 forward gears if you split all of them.
chuck stevens is offline   Reply With Quote
Old 07-20-2022, 06:44 AM   #5
corvette8n
corvette8n's Avatar
Anxiously waiting for the next installment, I like this project.
Old 07-20-2022, 07:50 AM   #6
deuce5wndw
deuce5wndw's Avatar
Wow Mart this is some project! Looking forward to watching this!
deuce5wndw is offline   Reply With Quote
