How to remove and install valve seats?
To remove- get washers that fit into the inside of the seat.
I used a stick welder to weld the washer to the inside of the seat. Does not need to be perfect. This will shrink them, they will be easy to remove. I had a company called K.O.Lee make 16 new seats to my measurements. I took some plumbing parts to make a guide- fits the inside and flat top of the seat, extends into the lifter below- so the seat is driven in perfectly flat- with a hammer. I lube with never seize. This worked for me- I have had the experience using proper machinery. (on other engines). For many, this will be best to take to someone with the tooling and experience. Karl |
thank you
I have removed the seats by just welding on the seat this easily shrinks them and they fall out and sometimes just break into pieces.
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
What RR said, quick & easy.
Gramps |
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver…RIP |
A job best left to a good machine shop.
#8 | |
Its easy to see the insert inner edge. If someone tried to do what you wrote they really need glasses.
We just put a small bead with the TIG you do not need to weld all around the seat. Three spots normally will shrink them. I no longer can see good enough and keep my hands still so this job has been passed on to the next generation. Trying to train the third generation but my 12 year old grandson shows no interest in greasy old machines.
#10 | |
JWL Senior Member Join Date: May 2010 Location: Fitzgerald, Georgia Posts: 2,197 Default Re: Valve seats. How to remove? Yes, a quick weld on the seat about as fast as possible. Ring will simply fall out. One word of caution---I once knew a guy to whom I explained my technique. Only too late he realized his block did not have seat rings. Ugly. Never changed them myself but I remembered reading this …..Mark
