#21 |
Roy Nacewicz has recessed nuts. Well I should say in his catalog,but his slogan is "We have your nuts"
"Never complain,never explain"... Henry Ford II |
#22 |
Anybody used Inline Tube or Classic Tube Oil lines? If you have do they fit? How about those amazing nuts - what size/ thread #? ALSO the .060 restrictor, same question what size/ thread?
THANKS!
Craig 89, 69, 53, and 40 Mercs |
#23 |
Just make your own lines from !/4" brake line from the store. The .060 restriction can be made by brazing up the end of a fitting, and drill it with a 1/16 " bit, roughly the same thing. Fittings are all 1/14" male pipe thread, and 1/4" female flare like a brake line, all available at the store
#24 |
Here's studs I used to mount the filter canister on an 8BA with early style heads.
I removed original head bolts one at a time and installed them one at a time. Those recessed nuts are best idea for studs. Last edited by 19Fordy; 11-07-2021 at 08:22 AM. |
