Old 05-01-2013, 11:25 AM   #1
old46ford
Default Where/how to mount factory oil filter on a 59ab
I have a 59ab in my coupe, the oil filter is currently not installed and bypassed. I have the filter with the bracket attached with 3 holes. Does it get mounted using headbolts? If so, I probably shouldn't loosen any head bolts to mount it and wait until I remove the head one day?
The factory oil lines are there, just spliced with a rubber hose.
old46ford is offline   Reply With Quote
Old 05-01-2013, 11:34 AM   #2
ken ct
Default Re: Where/how to mount factory oil filter on a 59ab
I would NOT use spliced rubber oil lines.The original flexible oil lines with the banjo swedched on are impossible to fine in usable shape. Your only option is to hard pipe it. I removed the original setup on my 36 because of line problems. Dont even bothet putting one on its only a by-pass partial filter anyway. Just change the oil a little more often.OMO from experiance with the system. ken ct.
ken ct is offline   Reply With Quote
Old 05-01-2013, 11:39 AM   #3
Vic Piano
Vic Piano's Avatar
The oil filter canister for the "46 - '48 59A mounts toward the front of the head on the driver side. If the car once had an oil filter (OEM) there should be three longer head studs that the canister mounts to.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 05-01-2013, 12:38 PM   #4
old46ford
Funny thing, is that the studs aren't longer where you would have mounted the filter, but I have a line coming up from the pan area (solid line) and and a line coming out of the rear of the engine (oil pressure gauge area)... both are connected on the side of the engine with about 8 inches of rubber line. The line has an older, but professional looking steel wire wrapped around it as connecters on the ends. Can I just remove the steel lines and put plugs in the holes?
Old 05-01-2013, 12:41 PM   #5
old46ford
Old 05-01-2013, 12:41 PM   #6
old46ford
see pic... the rubber line (been there for years) is in the center of the pic.
Old 05-01-2013, 01:03 PM   #7
51 MERC-CT
51 MERC-CT's Avatar
Yes, you can remove and plug the rear hole on the block (pressure feed)
I believe it's 1/4 pipe.
The one on the front can be removed and plugged also this is oil return from filter (no oil pressure)
Old 05-01-2013, 01:05 PM   #8
old46ford
Thank you so much!
Old 05-01-2013, 01:57 PM   #9
Henry/Kokomo
Henry/Kokomo's Avatar
If you install a stock 59ab oil filter, there are three special nuts which go on the stock studs to hold the filter housing. There is a cylindrical portion on each nut, below the hex portion, that sit in recesses in the filter mounting bracket. This arrangement allows you to use the stock length head studs. FWIW
Henry
Henry/Kokomo is offline   Reply With Quote
Old 05-01-2013, 02:11 PM   #10
old46ford
safe to remove three of the current nuts, without messing up the torque on the head?
Old 05-01-2013, 10:05 PM   #11
Roger W Gerow
Should you decide to mount an original oil canister in the proper position, I just happen to have three of the correct head nuts the canister. They have is shoulder that centers on the holes in the canister. Make sense?
Roger W Gerow is offline   Reply With Quote
Old 05-01-2013, 10:20 PM   #12
Merc Cruzer
Merc Cruzer's Avatar
Maybe this will help...I added the second picture as it was pointed out the filter is on the wrong side. The second picture is of the same engine when I picked it up. I bought the engine originally just to take it apart and learn. I then sold it for the same price I bought it for....$300. Sorry for any confusion.
Merc Cruzer is offline   Reply With Quote
Old 05-01-2013, 10:36 PM   #13
Marvin/TN
Send a message via AIM to Marvin/TN
My 46 59 AB has the oil filter and it is plumbed with hard lines both in and out with no rubber hoses
Marvin/TN is offline   Reply With Quote
Old 05-02-2013, 07:26 AM   #14
37 Coupe
37 Coupe's Avatar
It is a nice picture of a 59AB but it is going to be confusing to the poster who asked where to mount the filter canister.This is definitely the wrong side, it could work but everything to supply and return the oil is on the other side,this would entail longer lines for what reason? The early 1946 Ford oil pans had the oil return fitting on the drivers side forward of the pan,this was later changed to the fitting now added to the dipstick boss to get returned oil closer to pump. The picture shows the special headnuts for oil filter canister if stock length studs are used.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 05-02-2013, 09:08 AM   #15
old46ford
Can I remove the three current nuts without messing the torque on the head? Much appreciated
Old 05-02-2013, 09:14 AM   #16
Steves46
Steves46's Avatar
Roy Nacewicz should have them. His website is www.fordscript.com
Very nice fellow to deal with.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 05-02-2013, 09:19 AM   #17
37 Coupe
37 Coupe's Avatar
I wouldn't worry about it I have taken these off to paint etc and never had a problem. I personally like the filter probably from over 40 years ago restoring a couple 1946 Fords.I don't care what anybody says about it being a bypass filter and is not efficient I think it is better than no filter at all, definitely has crud in it when changing and if you don't think much oil goes through it see what happens if you don't have lid or a fitting snugged down.
Old 05-02-2013, 09:31 AM   #18
old46ford
Where did you get those recessed nuts?
Old 05-02-2013, 09:45 AM   #19
Barlea
Mine just got that way in my late sixties.... ..B.
Barlea is offline   Reply With Quote
Old 05-02-2013, 09:56 AM   #20
old46ford
Too funny
