Old 11-03-2021, 09:24 AM   #1
PeteVS
PeteVS's Avatar
Default Fit too tight for grease?
I lapped in my kingpin and pedal bushings. Grease goes into them but I really have to crank on the grease gun. Is this a problem?
Old 11-03-2021, 09:28 AM   #2
alanwoodieman
Default Re: Fit too tight for grease?
do your bushings have spirals cut into them? if so then no, if not then yes
Old 11-03-2021, 09:29 AM   #3
woodiewagon46
I did read about using a heat gun to get the area warm so the grease will flow easier.
woodiewagon46 is offline   Reply With Quote
Old 11-03-2021, 10:21 AM   #4
325w
Had a project 54 Chevy. Couldn’t get the front zerts to take grease. Warmed them up with a small benzene torch. Worked great. Pushed some really old grease right out.
325w is offline   Reply With Quote
Old 11-03-2021, 11:56 AM   #5
JT FORD
JT FORD's Avatar
Get the wheels off the ground for the king pins that helps.
JT FORD is offline   Reply With Quote
Old 11-03-2021, 01:58 PM   #6
woodiewagon46
Also as JT points out, after lifting the wheels off the ground, I lube the kingpins in my '46 Woodie with a shot of grease in the extreme left position and a shot in the extreme right position.
Old 11-03-2021, 04:24 PM   #7
Kube
Super Moderator
Kube's Avatar
Yes sir! ALWAYS remove the weight from the spindle pins when attempting to grease.
Old 11-04-2021, 02:48 PM   #8
GB SISSON
GB SISSON's Avatar
Or 5 more seconds with the slotted dowel and 120 grit.
GB SISSON is online now   Reply With Quote
Old 11-04-2021, 08:02 PM   #9
Kurt in NJ
Kurt in NJ's Avatar
the bushing next to the thrust bearing should have a passage that goes to the bearing that should take grease easilly and show excess around the thrust bearing
Kurt in NJ is online now   Reply With Quote
Old 11-04-2021, 09:42 PM   #10
PeteVS
PeteVS's Avatar
I took the pedals out and put a small burr into the Dremel. I cut some shallow grooves out from the hole for the fitting, put a fresh tube of grease with Moly in the gun and it went in very nicely. Thanks guys!
As an aside, the grease that was in the gun had been leaking oil out for sometime and it was around freezing this morning when I started. It was hard as could be. Should I start with a fresh tube if the grease has been sitting for a long time and has left a puddle?
