Old 04-13-2021, 09:58 AM   #1
JMFL36
JMFL36's Avatar
Default 34 Phaeton Top Irons
I'm thinking of getting my top irons restored (re-chromed). Has anyone done this recently? Other than removing the irons from the car and wood bows, does each piece have to come all apart? Any recommendations for vendors who do this sort of thing?
Document your car with CollectorCarCompanion
JMFL36 is offline   Reply With Quote
Old 04-13-2021, 10:03 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 34 Phaeton Top Irons
I did a '35 roadster top irons many years ago.Yes to do it right it has to all come apart.At the time I had Ezra Welding reassemble them as they need to be riveted together.They no longer are around.Maybe someone is continuing their work.
Old 04-13-2021, 11:55 AM   #3
DavidG
DavidG's Avatar
There's only one way to do it and have it come out well and that is to take it apart, have new stainless steel rivets made and then reassembled. But do not disassemble both sides at once. Do one side, send the pieces off to the plater and when they're done use the still-assembled original other side set of top irons for a mirror image pattern to reassemble the newly-plated other side. No matter how many photos you take, you will thank your lucky stars for not doing both sides at the same time.
Old 04-13-2021, 12:25 PM   #4
David J
David J's Avatar
FWIW I have an extra set with a little factory plating left on them .
If you want to do yours all at once I could borrow you these as patterns for re-assy .
Shipping won't be bad and it would speed up the process .
David J is offline   Reply With Quote
Old 04-13-2021, 03:03 PM   #5
V8ER
Qual Krom in Erie, PA replated my '36 phaeton top irons. They disassembled one side, replated, reassembled, then did the other side, all with correct rivets. Talk to Bob Ore.
V8ER is online now   Reply With Quote
Old 04-13-2021, 03:47 PM   #6
mercman from oz
mercman from oz's Avatar
That corrosion on the Top Irons certainly does not look good.
Old 04-13-2021, 04:07 PM   #7
Hitman
If you don't mind sharing, I'd be curious to know how much that cost, and how long ago it was.
I have a 36' top that will need plating, but I'm dreading the chrome bill. I'd expect at least $1000 in plating for the top pieces.
Hitman is offline   Reply With Quote
Old 04-13-2021, 04:08 PM   #8
mercman from oz
Painted Top Irons in Australian assembled 1934 Ford Phaeton.
Old 04-13-2021, 04:46 PM   #9
DavidG
DavidG's Avatar
Black-painted '33-'34 phaetons and roadsters are original on Australian-produced versions as well on the North American standard versions.
Old 04-13-2021, 08:07 PM   #10
JMFL36
JMFL36's Avatar
Thanks, V8ER, for the recommendation. I'll contact Bob.
Anyone else have a vendor they would recommend?
Old 04-14-2021, 02:48 PM   #11
V8ER
Qual Krom: $1600 in 2017, including all needed rivets and bolts, and disassembly and reassembly labor. Each piece is priced individually. There is never a quality issue, and the job will always be done when Bob says it will be done. I have always been pleased with their work.
Old 04-27-2021, 07:00 PM   #12
JMFL36
JMFL36's Avatar
Qual Krom gave me a quote of $2400. Yikes! I'll have to look around some more.
Has anyone tried coating top irons with one of those chrome paint products?
Old 04-28-2021, 07:42 AM   #13
rockfla
rockfla's Avatar
My brother painted a motor cycle fender the other day with some chrome paint and it looked pretty decent, still had a fair bit of orange peel in a few spots. I think the end results are driven by the amount of prep before painting as in this case the end results were not "Concours" driven, just everyday "Utilitarian" look good level. With a good prep job AND the right techniques I could see a "fair" to "Good" result going this route. The lastability I would question IF you raise and lower your top on a fairly regular basis and keep any kind of lube on all of your pivoting parts?? I also wonder IF the end results are also contingent upon what you are painting over as my brother painted over existing chrome??? Given the current environment and length of time between, a $700 increase over the last 4 years doesn't seem too out of line. I'm not sure the quality of the overall package AND I can certainly understand and get next to spending as little as necessary BUT there are few left that are chrome plating in the manor that Qual Krom is AND I would bet that in the next few years there are/will be even fewer still.......AND that to the fact of the quality of the workmanship and his ABILITY to handle the task.....I for one would be working as hard as I could to be sending my top frame to them!!! JMO hope it all works out for you
Old 05-04-2021, 10:16 AM   #14
JMFL36
JMFL36's Avatar
I'm in no hurry so I may first play with a chrome paint product to see how it looks. I'll post some photos once I get around to it. In the meantime I'm going to see if I can find another chrome outfit closer to me (Florida).
Old 05-04-2021, 01:44 PM   #15
Zeke3
Zeke3's Avatar
I saw a '35 grille that had been powder coated in a chrome finish that looked pretty good. It would probably give you a better finish than a rattle can.
Zeke3 is online now   Reply With Quote
Old 05-04-2021, 04:52 PM   #16
v8nut
v8nut's Avatar
I had my '35 phaeton top irons chrome plated after taking just one rivet out of each side. They came out very very nice. Maybe not good enough for Pebble Beach but plenty good enough for a Dearborn award. (We'll see about that if there ever is a Western National Meet again). Jim in San Jose
v8nut is offline   Reply With Quote
Old 05-04-2021, 08:09 PM   #17
JMFL36
JMFL36's Avatar
v8nut, who did the plating for you and do you remember how much? John
Old 05-07-2021, 12:34 PM   #18
v8nut
v8nut's Avatar
I was New Age Metal Finishing in Fresno CA. Cost was about $700. I like them. They have done all of the plating on my phaeton.
Old 05-12-2021, 11:04 AM   #19
Als48
Consider powder coating, as there are quite a few folks doing that these days. Much cheaper and almost as good.
Al Hook
Als48 is offline   Reply With Quote
