Old 12-12-2020, 01:13 PM   #1
Owlseye
Default 33 BB driveshaft?
I just noticed that the driveshaft tube on my 33 BB 157" wheelbase has a crack between the front knuckle joint and the next crossmember. Can this be welded or sleeved? Or do I have to pull everything and find a new intermediate tube? Gilda was right "It's always something!"
Owlseye is offline   Reply With Quote
Old 12-12-2020, 02:25 PM   #2
Bob C
Default Re: 33 BB driveshaft?
I don't see any problem with welding it.
Old 12-13-2020, 10:05 AM   #3
Owlseye
Thank you, I will try it and see if it is happy with it.
Old 12-13-2020, 11:58 AM   #4
Mart
Mart's Avatar
I'd like to see a photo of the crack before offering any advice on whether welding it is a good idea.
Is this a shaft or a torque tube?
If welding a shaft, it will bow towards the weld when cooling. You can mitigate this by putting a roughly equal amount of weld on the opposite side to equal it up.
But not knowing where the crack is, it is impossible to offer good advice.
Mart.
Old 12-13-2020, 12:17 PM   #5
john charlton
john charlton's Avatar
You probably know this anyway . If you remove the bolts holding the big tin cover to the back of the 4 speed you can slide the cover back down the tube . The big U/J is the two piece bolt together style . Take it apart and then you can remove the tube and get to it to weld the crack on your bench . It is fairly thin mild steel and will not distort if MIG welded . When it is apart you can change the seals in the front and rear "cups" .
John in Suffolk County England .
john charlton is online now   Reply With Quote
Old 12-13-2020, 02:37 PM   #6
Bob C
This is an AA coupling shaft, the same as the BB except the shaft is a little smaller.
