Old 11-10-2020, 12:04 AM   #1
49r
Default Brake Switch Wiring Connection
The original brake switch on my 49 F1 finally no longer works. In this original switch the prongs have a hole for the wires and grub screws to fasten them.
On this replacement switch how are the wires fastened to the prongs? There are no threaded screws or holes, only 2 grooves in each of the prongs.
Thanks in advance.
49r is offline   Reply With Quote
Old 11-10-2020, 02:08 AM   #2
fordcragar
fordcragar's Avatar
Default Re: Brake Switch Wiring Connection
You should be able to get some solder-less connectors that you can crimp onto the ends of the wires. Then push them onto the switch.
fordcragar is offline   Reply With Quote
Old 11-10-2020, 06:11 AM   #3
fortyonerag
fortyonerag's Avatar
They're called bullet connectors. Usually, the wires have male ends attached and connect together via a female 'tube' connector. Now you can also just get a female connector type. This is what you need. Commonly available.
fortyonerag is offline   Reply With Quote
Old 11-10-2020, 07:15 AM   #4
glennpm
glennpm's Avatar
Female bullet connector is required
glennpm is online now   Reply With Quote
Old 11-10-2020, 02:03 PM   #5
49r
That makes sense. Thanks for your help everyone.
