Old 05-13-2019, 10:11 AM   #1
ursus
Default Master Cylinder Gift Horse
I need to replace my 1940 Ford master cylinder and a friend offered to give me a new one from a Hudson of the same era. It has the same 3-hole mounting flange and overall length as the Ford MC. My friend is convinced it can be used in a Ford, but I'm not so sure. Any thoughts about such a switch?
Old 05-13-2019, 10:23 AM   #2
RalphM
RalphM's Avatar
Default Re: Master Cylinder Gift Horse
I don’t see why it wouldn’t work. When I built my first truck a 1945 commercial i used a master cylinder off of a military trailer from the 60s.
RalphM is offline   Reply With Quote
Old 05-13-2019, 10:39 AM   #3
skidmarks
skidmarks's Avatar
Clark forklifts used the same master cylinder. Just check the bore size
skidmarks is offline   Reply With Quote
Old 05-13-2019, 10:55 AM   #4
Terry,OH
Terry,OH's Avatar
Same diameter? If so should be good to go. I believe Dia. is marked on the side of the MC.
Old 05-14-2019, 02:52 AM   #5
Mart
Mart's Avatar
Master Cyl diameter needs to be 1-1/16".
Mart.
Old 05-14-2019, 05:52 PM   #6
revkev6
I bought a master cylinder off Ebay years ago that claimed it was a 39 Ford unit or a Hudson unit. When I got it the mount pattern is correct but the shape isnt ford. Looks like it may say 1" on it?
revkev6 is offline   Reply With Quote
Old 05-14-2019, 06:34 PM   #7
revkev6
Here's a pic of the casting number on mine
Old 05-15-2019, 10:08 AM   #8
revkev6
just did a litter research, based on the casting number the master cylinder I have is for a forklift and costs about $18. it's 1" bore. really, if it works it may be a cheap option for a master cylinder.... hudson has a master that is listed on ebay for 46-47 pickups that is similar looking to this unit which also has a 1" bore.
thoughts?? given the pain in doing the brakes twice I may just put this one on the shelf and spend the $40 on the correct master.
Old 05-15-2019, 10:24 AM   #9
JSeery
JSeery's Avatar
The small diameter mc will decrease the foot force required on the pedal for the same braking force at the wheels, but it will also increase the pedal travel. With a single chamber mc don't think that would matter much as long as the pedal travel is acceptable.
Old 05-15-2019, 10:29 AM   #10
revkev6
currently I have the same brake setup with a 39 style master in my 28 roadster. I have the brakes adjusted a little tight atm.... i get about an inch of pedal travel before it hits like a brick.
that makes me wonder if I could use the 1" but I get concerned about the stroke and such...
Old 05-15-2019, 02:12 PM   #11
ursus
The MC in revkev6's photo resembles the one I was considering. Interesting comment by JSeery regarding the effect of using one with a reduced the bore size - it makes sense from my limited experience with hydraulic stuff. I was hoping somebody with experience using the Hudson MC in a 39-48 Ford might comment here.
Old 05-15-2019, 03:53 PM   #12
modeleh
modeleh's Avatar
A smaller piston will result in more input effort.
modeleh is offline   Reply With Quote
Old 05-15-2019, 04:32 PM   #13
tubman
tubman's Avatar
I don't think so. The smaller the diameter, the less fluid has to be moved per a given amount of pedal travel. Less fluid moved, the less the effort. Your only worry is running out of pedal travel. Imagine a master 1/8" in diameter; you'll have to have a lot of travel to move the same amount of fluid as one 1" in diameter, but it sure would be easy to push.
Old 05-15-2019, 05:27 PM   #14
JSeery
JSeery's Avatar
Nope, smaller diameter, less foot pressure and more line pressure, but increased pedal travel.
Old 05-15-2019, 10:52 PM   #15
modeleh
modeleh's Avatar
Disregard
Old 05-16-2019, 07:03 AM   #16
Frank Miller
Frank Miller's Avatar
There will just be a bit more travel before the shoes tighten up on the drums. Like a hydraulic jack, once it has pressure on it every movement is exerting pressure. I wonder if hudson wheel cylinders are the same diameter as Ford? If so you're just copying their engineering.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
