The Ford Barn
-   -   Master Cylinder Gift Horse (https://www.fordbarn.com/forum/showthread.php?t=263317)
ursus 05-13-2019 10:11 AM
I need to replace my 1940 Ford master cylinder and a friend offered to give me a new one from a Hudson of the same era. It has the same 3-hole mounting flange and overall length as the Ford MC. My friend is convinced it can be used in a Ford, but I'm not so sure. Any thoughts about such a switch?
RalphM 05-13-2019 10:23 AM
Re: Master Cylinder Gift Horse
I don’t see why it wouldn’t work. When I built my first truck a 1945 commercial i used a master cylinder off of a military trailer from the 60s.
skidmarks 05-13-2019 10:39 AM
Clark forklifts used the same master cylinder. Just check the bore size
Terry,OH 05-13-2019 10:55 AM
Same diameter? If so should be good to go. I believe Dia. is marked on the side of the MC.
Mart 05-14-2019 02:52 AM
Master Cyl diameter needs to be 1-1/16".
Mart.
revkev6 05-14-2019 05:52 PM
I bought a master cylinder off Ebay years ago that claimed it was a 39 Ford unit or a Hudson unit. When I got it the mount pattern is correct but the shape isnt ford. Looks like it may say 1" on it?
revkev6 05-14-2019 06:34 PM
2 Attachment(s)
Here's a pic of the casting number on mine
revkev6 05-15-2019 10:08 AM
just did a litter research, based on the casting number the master cylinder I have is for a forklift and costs about $18. it's 1" bore. really, if it works it may be a cheap option for a master cylinder.... hudson has a master that is listed on ebay for 46-47 pickups that is similar looking to this unit which also has a 1" bore.
thoughts?? given the pain in doing the brakes twice I may just put this one on the shelf and spend the $40 on the correct master.
JSeery 05-15-2019 10:24 AM
The small diameter mc will decrease the foot force required on the pedal for the same braking force at the wheels, but it will also increase the pedal travel. With a single chamber mc don't think that would matter much as long as the pedal travel is acceptable.
revkev6 05-15-2019 10:29 AM
currently I have the same brake setup with a 39 style master in my 28 roadster. I have the brakes adjusted a little tight atm.... i get about an inch of pedal travel before it hits like a brick.
that makes me wonder if I could use the 1" but I get concerned about the stroke and such...
ursus 05-15-2019 02:12 PM
The MC in revkev6's photo resembles the one I was considering. Interesting comment by JSeery regarding the effect of using one with a reduced the bore size - it makes sense from my limited experience with hydraulic stuff. I was hoping somebody with experience using the Hudson MC in a 39-48 Ford might comment here.
modeleh 05-15-2019 03:53 PM
A smaller piston will result in more input effort.
tubman 05-15-2019 04:32 PM
I don't think so. The smaller the diameter, the less fluid has to be moved per a given amount of pedal travel. Less fluid moved, the less the effort. Your only worry is running out of pedal travel. Imagine a master 1/8" in diameter; you'll have to have a lot of travel to move the same amount of fluid as one 1" in diameter, but it sure would be easy to push.
JSeery 05-15-2019 05:27 PM
Nope, smaller diameter, less foot pressure and more line pressure, but increased pedal travel.
modeleh 05-15-2019 10:52 PM
Disregard
Frank Miller 05-16-2019 07:03 AM
There will just be a bit more travel before the shoes tighten up on the drums. Like a hydraulic jack, once it has pressure on it every movement is exerting pressure. I wonder if hudson wheel cylinders are the same diameter as Ford? If so you're just copying their engineering.
