Old 04-27-2019, 09:27 PM   #1
big deuce
big deuce's Avatar
Default flathead engine cradle
Looking for pics of a flathead engine cradle/stand that mounts on both the front and rear of the block, from what I remember. Any pics?
big deuce is offline   Reply With Quote
Old 04-27-2019, 09:28 PM   #2
Tim Ayers
Default Re: flathead engine cradle
Are you talking about the one that allows you to rotate it while it's in the cradle or just wheel it around?
Old 04-27-2019, 09:36 PM   #3
big deuce
big deuce's Avatar
Yes, rotating while it's in the cradle. Seems I remember a pic where there was a circle, or semi circle on each end that it rotated on.
Old 04-27-2019, 09:37 PM   #4
cas3
i make em to mount on the exhaust flange's, like the motor rebuild stand, but two with wheels. pics tomorrow, its dark and i get scared out in the barn
Old 04-27-2019, 09:39 PM   #5
cas3
opps, wrong stand. why support on both ends instead of the side?
Old 04-27-2019, 09:49 PM   #6
big deuce
big deuce's Avatar
I believe this is the style I was searching for
Old 04-27-2019, 10:08 PM   #7
big deuce
big deuce's Avatar
Why not support it on both ends?
Old 04-28-2019, 03:00 AM   #8
Kerk
I think you are looking for the Clayborn type stand. Have a couple BUT not the adapters for each end. Just have one set of the adapters which I had copied from originals. sorry I can not give more info or pictures . kerk
Kerk is offline   Reply With Quote
Old 04-28-2019, 05:17 AM   #9
flatheadmurre
flatheadmurre's Avatar
I have 3 of them Claybourne stands...love them.
You can install the camshaft with it attached thats why it has a large hole in one end.
You can easily throw the boringbar on it won´t break a sweat..
Beats a sidemount any day !
Old 04-28-2019, 05:45 AM   #10
Don Rogers
Don Rogers's Avatar
Here's an image from Ford Field Magazine.
Don Rogers is offline   Reply With Quote
Old 04-28-2019, 05:49 AM   #11
big deuce
big deuce's Avatar
Yes, that the one. Thanks for the input!
Old 04-28-2019, 08:27 AM   #12
Don Rogers
Don Rogers's Avatar
Here's a couple of photos of the end pieces.
Old 04-28-2019, 08:48 AM   #13
KiWinUS
KiWinUS's Avatar
Great stand , I have the stand but need the 2 end pieces that Don has pictured above. I believe my Clayborne stand my have come from Don.
If anyone has the two ends pictured above & would part with them I would be very interested.
Thanks
Cheers
Tony
Old 04-28-2019, 09:48 AM   #14
Tim Ayers
I want a Clayborne as well. I think more than a KR Wilson. The Clayborne also you to port both sides.
Old 04-28-2019, 05:02 PM   #15
Zeke3
Zeke3's Avatar
Thanks, I learned something today and if I ever see a Clayborne engine stand at a swap meet I will know what I am looking at and will treat it with respect. Time to go get the pizza.
Zeke3 is offline   Reply With Quote
Old 04-28-2019, 08:51 PM   #16
paul2748
paul2748's Avatar
If these are not being currently made, I bet Stumpy's Fab works would make these up if some one gave him the specs or a sample
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-29-2019, 12:43 AM   #17
flatheadmurre
They are not that easy to copy if you want an accurate copy since some pieces are cast.
A modern version with CNC machined part will not be very cheap either sadly.
Old 04-29-2019, 07:30 AM   #18
tubman
tubman's Avatar
I wouldn't think they would be too hard to fabricate, would they? A 2" slice off a 6" (or so) steel pipe and some 1/4" X 2" steel strap and you're well on your way to making the first (circular) part. A piece of the proper sized tubing, a steel plate, and some proper sized bolts and you have the second. Granted, it would take some cutting and welding, but if I had the stand without those parts, I would be at the steel supply shop this afternoon, digging through the "Drops" bin.
Old 04-29-2019, 08:05 AM   #19
Kerk
I nhave the stands so if anyone has the end pieces I would be interested. I would swap the stand for the end pieces !! kerk
Old 04-30-2019, 09:19 PM   #20
big deuce
big deuce's Avatar
I ran across this stand, had the Clayborne tag on it, but not sure of application. For sure not flathead.
